![]() | #1 |
Newbie Join Date: Apr 2020 Location: Independence
I have been eyeballing the Injora ar44 clone axles... One of my first questions would be do parts from the actual ar44 swap into this axle? Or is everything proprietary? Externally they look pretty darn similar Do they hold up or are they junk? The price is certainly right but that might not be a good thing |
![]() | #2 |
Slow is the new fast ![]() Join Date: Nov 2013 Location: Winterpeg
Onjora is going to be hit-and-miss on quality, I imagine. I have some of their wheels and they do the job. In my opinion you should forgo both Onjrara AND Axial. Instead pick up a set of SSD Pro44 complete axles. They are Ar44 compatible but better Buy once, cry once. Buy twice... |
![]() | #3 | |
| ![]() Quote:
az for durabuility i wouldent know but it is made in china using chineezium butter steel so i guess it would depend on what your running them on a light weight 1.9 low powered crawler your probably fine but a say scx10 with a 540 motor i wouldent exspect them to hold up to well thats just my opinion for what its worth | |
![]() | #4 |
Quarry Creeper Join Date: Jun 2013 Location: Portugal
I've used Injora hi-pinion pinions on my Unimog project(scx10.2 replacement) and they didn't last long and not smooth.
![]() | #5 |
RCC Addict Join Date: Jun 2008 Location: Mudville
Most of these cheap Chinese axles are just pot metal or poor 5055 or some other low quality metals. threads will strip easy in most cases. especially if they are a multi piece axle, ie the tubes bolt into the pumpkin etc. those bolts get just a little loose and heavy stress will cause them to get loose, and the next thing you know the threads are gone, and you can't buy just a replacement part. There is a reason even Treal and Vitavon, which are fully Chy-Na companies, are still 130-160 per axle. Because they are using quality materials and are doing their own designs, where companies like Intejunk or Injunka just steal a design, and hit copy and past and run on their pot metal machines, then sell this crap for 10000% mark up over its real value...and are still only 40ish % cost of actually well made gear from good quality metals. jm2c. Besides, you'll never attend an Injunka or Intejunk sponsored RC Event. Ever. they only take money to Chy-Na, and not give back. |
![]() | #6 |
ill only buy potmetal axles even if i have to finnish the machining my self the trick is to clean the threads and bearing pockets and use lots of locktight aluminum is pointles anywere it could contact a rock its like tossing out a anchor at that point atleast potmetal slides on the rocks |
Austar/Injora SCX10 clone for $79 | Wormbomber | Axial SCX10 II | 6 | 04-21-2022 04:15 PM |
SCX10 ii clone chassis (Injora): 2000 Jeep Cherokee XJ scale build | marcod13 | Axial SCX10 II | 74 | 12-06-2020 06:45 AM |
Injora SCX10 ii clone | nzrc | 1.9 Scale Rigs | 14 | 08-27-2019 08:45 PM |
Rc4wd portal axles for axial ar44 axles scx10 ii | soze | General Crawlers | 1 | 06-04-2019 02:12 AM |
