01-21-2022, 05:18 PM | #1 |
Quarry Creeper Join Date: Jun 2018 Location: Blaine
| Element IFS compatibility question
By my understanding, the Element, 10.2 and Trail King are all pretty similar. Does anybody know if they're similar enough that I could mount the Element IFS let to the TK chassis? With or without the 10.2 conversion kit? My apologies ahead of time if this should be brand specific but I wasn't sure where to put it. I tried to search for topics discussing this compatibility but couldn't find anything Sent from my LM-V600 using Tapatalk |
01-21-2022, 05:29 PM | #2 |
| Re: Element IFS compatibility question
I'm pretty sure the TK motor position would land right where the IFS kit needs to go so I'd wager it wont fit. If you swapped to a different tranny I'm sure it could work. |
01-21-2022, 05:39 PM | #3 | |
| Re: Element IFS compatibility question Quote:
I'm mainly curious about the chassis holes and chassis shape though as I might be able to use a shorter motor or relocate the servo if necessary (I could change the transmission but that would eliminate one of the features I want from the TK). But I'm not sure if the TK chassis would be compatible or if it would need a special mounting plate Sent from my LM-V600 using Tapatalk | |
01-21-2022, 05:57 PM | #4 |
I have both trucks but I posted this while I was at work hoping anyone could offer a definitive answer so I wouldn't have to tear apart my two favorite trucks Taking a closer look at my Knightrunner, I see the frame rails are very flat in the front compared to the TK/scx10.2 syle chassis. So I imagine I'd need the 10.2 conversion at least. But it appears I could make the TK motor/transmission fit (barely) with slight modification to the E-IFS if I relocate the steering in some way. The square shows the approximate location of the end of the TK motor relative to the IFS on the KR Sent from my LM-V600 using Tapatalk |
01-21-2022, 10:10 PM | #5 |
Rock Crawler Join Date: Jan 2022 Location: st louis
The way your motor/transmission is set up, ain't gonna fit the IFS. The rest of the chassis, it's possible. Seeing as they give you almost everything for solid axle front conversion with the KR, can't see parts not swapping out without too much pain to put IFS in another rig (especially seeing as they sell just the IFS). Still trying to figure out why they only gave most, not all the parts for solid axle conversion in the KR though.... Sent from my SM-N975U using Tapatalk |
01-21-2022, 11:48 PM | #6 | |
There's a decent gap between the mounting plate and the differential that's only occupied by the servo and the link to the bell crank. With those out of the way, the motor looks like it could fit in that gap. Side note: I didn't even notice the KR didn't come with everything for a straight axle conversion. I wanted an IFS specifically so I didn't even look at the included axle parts. Sent from my LM-V600 using Tapatalk Last edited by smc-93; 01-21-2022 at 11:51 PM. | |
01-22-2022, 03:13 PM | #7 |
I didn't "look" at the parts really, have no real desire to use them. But it came with a bunch of parts I was confused why they were included so I looked at the manual. But then also realized some parts would be missing for that to work. Also came with a dual servo plate I have no clue what its for lol. Sent from my SM-N975U using Tapatalk |
01-22-2022, 04:01 PM | #8 | |
Well the dual servo plate is so you can install a servo winch after you complete the half straight axle conversion Sent from my LM-V600 using Tapatalk | |
Element IFS compatibility question - Similar Threads | ||||
Element Enduro IFS | MrCataract | General Crawlers | 2 | 06-02-2021 07:22 AM |
Crazy Question, Will the element IFS kit fit a GS02? | mass-hole | G-Made Crawlers | 4 | 05-02-2020 04:59 PM |
