10-28-2007, 10:41 PM | #21 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
speaking of Punisher shafts, how do you like them?
10-29-2007, 10:16 AM | #22 |
Rock Stacker Join Date: Sep 2007 Location: Seattle
x2. Though, I've read on here the quality is, um... lacking? :-( |
10-29-2007, 01:30 PM | #23 |
Yeah - thats why I asked. I'd like to run them as my project might have a pretty long wheel base.
10-29-2007, 03:20 PM | #24 |
Here's something I ran across a short time ago, referring to the punishers as something less than overwhelming... http://www.rccrawler.com/forum/showt...fts#post638174 |
10-29-2007, 03:54 PM | #25 | |
Quarry Creeper Join Date: Aug 2007 Location: Lumberton
how did you get 40 series on wk axles. another question to anyone. will a pede tranny fit in a stock wk tranny pm me anyone if you've got a anwser for either question. please and thank you. Quote:
10-29-2007, 06:48 PM | #26 | |
And you'll need a custom chassis to run a pede tranny. | |
10-29-2007, 07:15 PM | #27 |
10-29-2007, 07:26 PM | #28 | |
I like the pede in a trail rig, when I built Bumblebee for my daughter I put one in there. I like that it has a slipper for when she is bashing around. The durability of a pede is really good and replacement parts are cheap and easy to get. For most of my bigger brushless motors I really like to run a 15 - 16 tooth pinion and an 87 tooth spur. With a brushless setup you can destroy either tranny, the slipper clutch is what make the pede survive imo. | |
10-29-2007, 07:35 PM | #29 | |
I'm thinking just go all out on the power side as a pede would be easier/cheaper to replace. | |
10-29-2007, 07:38 PM | #30 |
The R2 gear ratio is adjustable from 10:1 to 30:1, by changing the pinion. I ran a pede for a year without ever having a problem. I have destroyed some R2's, but too much horsepower will do that to any tranny, although a slipper can help(it didn't help the 5 Emaxx tranny idler gears though) . I like the compact size of the R2, I had one in my scaler, but recently I picked up a couple more pede's, as I feel the R2 needs to be maintenanced/lubed often to keep it alive, and the pede doesn't. Also, it is nice to be able to run a smaller spur gear to get some wheelspeed, with the same size pinion, so the motor can work a little easier. With the R2, if you want more wheelspeed, you either gear up the pinion or add more cells.
10-29-2007, 07:39 PM | #31 |
Replacement gears for the R2 are only $15. |
10-29-2007, 08:00 PM | #32 |
I think I'll go with the pede first because of cost, then maybe an R2 when a rebuild is in order.
10-29-2007, 08:23 PM | #33 |
I'm sure the you'll be happy with the pede, I was until I wanted something smaller for the comp rig, I still like it for certain trucks, like snow/mud bashers. |
10-29-2007, 09:01 PM | #34 | |
Quarry Creeper Join Date: May 2007 Location: Brenham, Tx
http://www.crawfordperformanceengine...A6&log_pid=yes edit: just saw these and they look perfect to run axial beadlocks like mine http://cgi.ebay.com/12mm-to-17mm-Ada...QQcmdZViewItem | |
10-30-2007, 03:54 PM | #35 |
so which tranny you going wit. hey man thanks for the links. |
10-30-2007, 04:09 PM | #36 |
Me? I'm getting a pede. |
10-30-2007, 04:27 PM | #37 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
Pede ftw , Im building a chassis around it as we speak, of course its a crappy chassis out of steel |
10-30-2007, 05:17 PM | #38 | |
Rock Crawler Join Date: May 2007 Location: Valdosta
| R2 question Quote:
10-30-2007, 05:48 PM | #39 |
My guess to it being loud is the metal gears and maybe not enough lube.
10-30-2007, 05:54 PM | #40 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
vote pede tranny for the basher |
