Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: lets see your 1.9 clod trucks
Old 07-29-2013, 11:41 AM   #101
Monday bump with a picture from my outing this morning by the lake.
ah_5500 is offline   Reply With Quote
Old 07-29-2013, 07:31 PM   #102
And after the run. Depressing...
Old 01-09-2014, 05:17 PM   #103
Bringing an old thread back up with an update of one of mine.
Old 01-12-2014, 09:13 PM   #104
Default Re: lets see your 1.9 clod trucks
Some nice looking rigs in this thread. I have a question for those who have cut there body, especialy those who pinned in the front end...
What are you using to cut the body to get the cleanest cut? Also what are some good materials to work with for finish work, I know styrene is a main material but what kinds of glues and body filler, etc.?
LIKES2CRAWL is offline   Reply With Quote
Old 01-13-2014, 06:59 AM   #105
Here is a list of tools I use for just about any hard body.
Cutting
Thread
X-acto knife kit or Excel knife kit
X-acto med saw blade
Glue
Plastic weld
Plastruct bondene
Shoe glue
E 3000
Body filer
Evercoat metal glaze , it doesn't shrink or crack or bleed thru paint.
CrewCab59 is offline   Reply With Quote
Old 01-21-2014, 06:07 PM   #106
Cutting
Thread
Glue
Plastic weld
Plastruct bondene
Shoe glue
E 3000
Body filer
Thanks for the info, I've heard of the thread cutting....but never seen it or tried it.
Old 02-09-2014, 02:42 PM   #107
Update from this weekends run. Had an awesome time at a new spot, or more like area! I also decided to run the boggers off the mud truck and it's a good thing bc there was some nasty muddy spots. Enjoy!
Old 02-09-2014, 02:50 PM   #108
still a work in progress but its getting there slowly
ecook280 is offline   Reply With Quote
Old 02-13-2014, 04:32 AM   #109
I have another question for those that pinned the front end. How do you pull the fenders in and get them to stay with all the tension on them? Are you heating up the body with a heat gun to kinda mold the plastic?
I tried the thread cutting method and it was kinda a pain but I think my thread was old and weak, took a while to make some cuts.
Old 03-09-2014, 09:28 PM   #110
Aren't they all a work in progress? Lol
Looks great man!
Frostman is offline   Reply With Quote
Old 03-10-2014, 12:56 AM   #111
Here is mine.almost done with it(well probably not)lol
What am I going to do with it?
hotrodsonoma is offline   Reply With Quote
Old 03-12-2014, 05:57 PM   #112
littletoyboy is offline   Reply With Quote
Old 05-31-2014, 08:54 AM   #113
Hwheeler73's Avatar
I'm not finished with it yet so it has yet to get dirty! LOL! I'm almost there though!
Hwheeler73 is offline   Reply With Quote
Old 05-31-2014, 09:14 AM   #114
Looks good. Did you narrow that rear trex axle?
Old 05-31-2014, 10:11 AM   #115
Hwheeler73's Avatar
Yes I did. About any inch total. I got the tires right up next to the leafs. I'm not sure how it's going to hold up in the long run but seems to be good right now. I haven't driven it much yet. I've been waiting on my foams from Crawler Innovations and then I can get the tires glued on.
Old 05-31-2014, 11:43 AM   #116
How did you narrow it?
Old 05-31-2014, 12:58 PM   #117
Hwheeler73's Avatar
I just cut out the same size sections on each side of the housing. Then used styrene glue to glue them back together and covered that with CA glue. I used zip ties on the outer ends to hold the halves together. After I got the housing the way I wanted it, I installed the axle shafts and marked out the length I needed. I pulled them back out and used a small bench grinder to turn them down to the size I needed to retread them, drilled my pin holes then used a die grinder to cut to length.
Old 07-03-2014, 10:34 AM   #118
Super stoked for this truck to be finished
Build thread coming soon
The Crawl Space is offline   Reply With Quote
Old 07-03-2014, 11:05 AM   #119
Attachment 287561
This is sick. Cant wait for build thread...........
1beatjeep is online now   Reply With Quote
Old 07-06-2014, 09:22 PM   #120
RC-Hopper is offline   Reply With Quote
