02-23-2012, 08:40 AM | #1 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| High Lift Steering Box - spline size?
Looking at using the shaft from a Tamiya High Lift steering box on a new build. It has splines on both ends for servo arms. I want to use more compact aluminum arms on it in my build. Does anyone know what spline this is? I mainly use Hitec servos and non of my arms fit. |
02-23-2012, 05:11 PM | #2 |
| Re: High Lift Steering Box - spline size?
Anyone have a link to a good servo spline reference page that gives spline count and diameter?
02-23-2012, 05:19 PM | #3 |
I think I counted either 14 or 15 splines. The shaft is 5mm. I found these links: servo wheel compaibilty fut,jr,hitec ??? - RC Groups RC Groups - View Single Post - expert servo arms Splines guide for standard servos Last edited by sweli; 02-23-2012 at 06:15 PM. |
02-24-2012, 02:24 PM | #4 |
If it only has 14 to 15 splines then its not a servo horn as they are all 23 to 25
02-24-2012, 03:19 PM | #5 |
Rock Crawler Join Date: Jul 2008 Location: E. City
I can confirm that no servo horns will fit it. The splines are much bigger than a servo horn. I'm pretty sure I have a complete spare set I'd sell to you if you want one. I'd have to check to be sure.
02-24-2012, 08:19 PM | #6 |
| Re: High Lift Steering Box - spline size? Thanks. I have a complete set though. 2shafts, 2mounts, 4 arms. I was just wanting to shave a little overall height of the assembly on build I am working on.
02-25-2012, 07:28 PM | #7 |
Oh ok. Well you might be able to cut down the shaft a little and then cut down the lower spacer part on the arm to lower it a little.
High Lift Steering Box - spline size? - Similar Threads | ||||
high lift steering servo help | nbaker | 1.9 Scale Rigs | 0 | 11-18-2009 07:55 PM |
High-Lift Mods (steering servo, track bar and body lift) | thefordmccord | 1.9 Scale Rigs | 5 | 07-17-2009 11:41 PM |
high lift bearing size? | infanterene | General Scale Talk | 4 | 08-07-2007 02:51 PM |
high lift steering? | dipstick | General Scale Talk | 1 | 02-22-2007 10:10 AM |
