05-02-2012, 04:44 PM | #1 |
Rock Crawler Join Date: Nov 2008 Location: missoula
| Driveshaft help
I have 145mm tranny to diff got driveshafts that are 155mm full extended end to end so i have 10mm entering female portion of driveshaft max is 20mm in. Seems like need a longer one still. Axial tranny wraith rear both have 5mm outputs.
05-02-2012, 05:17 PM | #2 |
| Re: Driveshaft help
I can get the punisher shaft which extends to 165mm would itbe worth changing for 10 more mm total 20mm inside thatway
05-03-2012, 10:16 AM | #3 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
10 is on the shy side but may work. I have a couple of rigs with shaft like this that I bought used MIPS and had a locl shop weld together for me, for $5. Can you clock the axle involved to get another 5+mm out of it? Sent from my U20a |
05-03-2012, 02:06 PM | #4 |
| Re: Driveshaft help
Ive clocked them all the way the shafts are straigt into tranny. These dont need to slide? If not ill make my own from steel tubing.
05-05-2012, 12:22 PM | #5 |
Pebble Pounder Join Date: Feb 2011 Location: Knoxville
I'm running MIPS for an ax10 with a summit male piece on the rear of my rig, I can't remember the length right now but it's super long. 14" wheelbase and only the rear links were extended.
Driveshaft help - Similar Threads | ||||
AX 10 Driveshaft Help | cmlooner33 | Axial AX-10 Scorpion | 4 | 02-26-2012 08:37 AM |
DriveSHaft help | ljrce | Axial AX-10 Scorpion | 4 | 01-28-2012 09:47 PM |
driveshaft? | bradabolics | General Scale Talk | 1 | 01-31-2011 07:58 PM |
driveshaft | GearLoDriveSlo | Team Losi Comp Crawler | 2 | 11-02-2009 09:48 PM |
driveshaft | MAX climber | Newbie General | 9 | 05-10-2007 05:15 PM |
