06-10-2012, 12:12 PM | #1 |
Quarry Creeper Join Date: Feb 2012 Location: Texas - just outside of Austin
| Cheap Portable Rock Obstacles
The most recent thing I've done is take some spare lumber destined for the trash and build some portable obstacles. I've built these so that I can lay them wherever I want across a trail (or in my case a flowerbed). I also built one to act as a ramp to access some of the large boulders I moved in my backyard when the house was built. I took some 4x4 landscape timbers which I was going to throw away and just started cutting them up at different angles on the compound miter saw. When I was at Ace yesterday buying cotter pins I picked up 2 cans of cheap gray primer (one light, one dark) and painted my creations in a gray camo to try and give the appearance of rock. FYI - the individual pieces are held to the fence picket with liquid nails which I followed up with one wood screw for each piece. With the combination of liquid nails and a screw holding each piece on they are extremely rugged. Pick a funky angle and cut! Figuring out how wide to make each obstacle Gray Camo paint to try and give a rock effect. I tried to make the surfaces light and the sides and cracks dark to give a shading effect. |
06-11-2012, 05:02 AM | #2 |
Pebble Pounder Join Date: Apr 2011 Location: Liverpool Y.N.W.A.
| Re: Cheap Portable Rock Obstacles
Great idea, Cheap and easy to build in large quantities Nice one
06-11-2012, 08:17 AM | #3 |
These have actually turned out to be a lot more fun than I thought they would. I've cranked out 5 more and they are like obstacle lego's! I didn't intend to place them next to each other but I quickly figured out you can put them next to each other in different arrangements and make a cool crawling course in a relatively short area.
06-11-2012, 08:28 AM | #4 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
Pretty sweet, and a lot lighter than rock.
06-11-2012, 01:34 PM | #5 |
Rock Crawler Join Date: Jul 2008 Location: E. City
You could also take some of the spray foam and fill in the gaps a little to get more of a slab effect. Or space them farther apart and use the foam to blend in the edges.
06-15-2012, 07:16 AM | #6 |
Rock Stacker Join Date: Jun 2012 Location: Here
This is a good idea. Easily portable and you could include plenty of elevation change with longer pieces. I may try this in the future.
06-19-2012, 03:33 PM | #7 |
Rock Stacker Join Date: Mar 2008 Location: Mundelein
These are pretty cool!! keep us posted on how they hold up and could you post some more pictures of them set up as a course?
06-19-2012, 07:27 PM | #8 |
No problem..I'll probably set em up this weekend and snap some pics (I keep them in the shed when not in use).
11-16-2012, 04:54 AM | #9 |
Pebble Pounder Join Date: Sep 2012 Location: Minnesota
Cool idea..are the dishes in case your truck gets thirsty on the "trail"? Thanks for sharing! JC |
Cheap Portable Rock Obstacles - Similar Threads | ||||
Need ideas for portable rock crawling obstacles | mijoso | Chit Chat | 7 | 06-17-2008 04:19 PM |
Rock obstacles to scale size | all_atv | General Crawlers | 6 | 11-07-2006 04:54 PM |
Man-made rock obstacles any info ? | RockRacer1 | Chit Chat | 28 | 11-01-2006 11:06 PM |
Scale size rock obstacles | all_atv | Chit Chat | 5 | 10-29-2006 08:42 PM |
