Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: Black Widow Axles - MiniMill has been busy
Old 08-03-2012, 05:07 AM   #1
Default Black Widow Axles - MiniMill has been busy
I picked up a set of Black Widow axles from TheSaundo (thx!!) without mounts or truss'.
Then found out it was $70 for the lower link mounts
Upper link mount doesn't exist.
I thought of brazing up some stainless, but these axles are so beautiful and angular I wanted to stay with the angles versus tubes.
Then thought about milling some delrin, but silver would look better.
Landed on some milling some alum.
My mini mill takes a long time with what carbide and high speed steel bits I have.
So far I have the rear truss and lower link mounts completed.
Lower link/shock mounts slide over axle tubes and pinch clamp in place.
Truss has two screws into beefy pumpkin and one down through the pinch clamp , into the axle tubes (anti rotation).
Truss has slot for third link, with a panhard mount out at the end.
The Black Widow axles allow for:
  • moving the short tube/long tube on either side
  • turning the ring and pinion around (spin opp. direction)
  • clocking or not clocking the axle
pics so far...............
sweli is offline   Reply With Quote
Old 08-03-2012, 05:10 AM   #2
Default Re: Black Widow Axles - MiniMill has been busy
My Sherline mill is purely manual and not schooled in millwork, so some dims and angles are off a little.
Angles are eyeball aligned when clamped
Old 08-03-2012, 11:16 AM   #3
Looks awesome, your milling work looks great also, can't wait to see the final assembly running on the trails
Joe&Jeep is offline   Reply With Quote
Old 08-03-2012, 07:16 PM   #4
Thanks Joe!!
One of those lllooonnngggggggggggggggg slow builds.
Old 10-19-2012, 05:06 AM   #5
Those were a set of axles I sold to him and honestly I wish I would have kept them instead of the set that had factory mounts..believe me the rc4wd mounts have much to be desired especially the top mount.. The other set I kept was a real pain to get mounted up on a 3 link panhard setup and no matter how I set them up the panhard bar mount(upper mount) bottoms out on the ball link. Your ahead of the game machining your own
docsrcrepair is offline   Reply With Quote
Black Widow Axles - MiniMill has been busy - Similar Threads
black widow axles ricroc General Crawlers 11 09-20-2010 03:08 PM
Black Widow axles fvrr General Scale Talk 7 07-26-2010 11:42 PM
