01-30-2013, 05:36 PM | #1 |
Rock Crawler Join Date: Mar 2011 Location: USA
| KMS K2 Free spool servo winch
It's on the bench just came away from the milling machine,,The K2 free spooling servo winch kit ,,, prototype,,, I have my blue prints done ,so parts are still to come ,It's not done but thought you would like to see it kinda like building a truggy or a jeep ,, I have it set where I push the shaft towards the servo and it freespools pull it back and locks the spool and servo gear back up ,, It is still in the early stages ,,,KMS,,, Yes the K3 will be next,if the testing goes well |
01-30-2013, 06:28 PM | #2 |
| Re: KMS K2 Free spool servo winch
You have my attention Any way to spring load it? |
01-30-2013, 07:38 PM | #3 |
Yyyyyup!
01-30-2013, 09:01 PM | #4 |
| Re: KMS K2 Free spool servo winch Oh yea thats covered ,,,,The old man building this thing just ran out of steam ,,I will make two cap nuts one for each end, the gear end will help hold the pin in place and cover end of shaft .The tail end will be the push to freespool ,as the main shaft will slide all the way threw to release ,When finger lifted the spring will push shaft back into the lock position ,Did a dry run and it worked great ,Tomarrow more updates .Should hopefully have it completed and start testing ,,For the K3 winch kit will be a week or so have to see how well this one holds up ,there is two spots that i need to watch for excess wear or distortion ,,Inside the spool and the servo gear end ,The gear end should be fine with the cap nut ,,Time & lifting will tell ,,,KMS,,,
01-30-2013, 09:18 PM | #5 |
Quarry Creeper Join Date: Dec 2011 Location: The land of snow
well now im just going to wait for this.... ha
01-31-2013, 05:38 AM | #6 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Very nice, this is exactly what is needed for this type of conversion |
01-31-2013, 10:15 AM | #7 |
Quarry Creeper Join Date: Apr 2012 Location: Missouri
Was just telling a guy from the club last weekend that I wished I could get a winch that freespooled |
01-31-2013, 10:25 AM | #8 |
| Re: KMS K2 Free spool servo winch Might be but it kicking my butt right now ,headed to the hardward store looking for the right spring ,,,KMS.... Last edited by KMS; 01-31-2013 at 01:11 PM. |
01-31-2013, 12:16 PM | #9 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
We have been talking about this for awhile - Thanks for working this. Once you have a free spool youll always wonder how you lived without...... |
01-31-2013, 02:55 PM | #10 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
I just drooled on myself!!
01-31-2013, 06:47 PM | #11 |
Ok its been a ruff day ,I need to make a new shaft . I feel that the measuernents are off ,,It works but not as good as I want it to , Here's a few pics,,It's been a long day,,,,,
02-01-2013, 10:34 PM | #12 |
Ok here it is The K2 Freespool winch ,and a sneak peak at the K3 free spool,,,Let the testing begin ,,,,KMS,,,, KMS Winches Free spool winch K2,K3 axial scx10 - YouTube |
02-01-2013, 11:05 PM | #13 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
Very nice option having feel spool. |
02-02-2013, 07:51 AM | #14 |
Great idea with adj spring tension on release.
02-02-2013, 05:17 PM | #15 |
Testing started at 10am and by 10:45 needed to make a new main shaft ,broke the main shaft ,The hole time winch was slippin ,Free spool works great just wont lift much weight with out slipping ,Got tired of messing around with the adjustment knob and replace it with a lock nut heavier spring ,Started fine lifting the 16lb bottle jack ,something clicked and down came the jack ,close inspection broke the gear in lower gear in the servo,,,Got butt kicked today ,,,,, |
02-02-2013, 09:06 PM | #16 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
Looks good man! Keep up the good work!
02-02-2013, 09:18 PM | #17 |
You'll work it out , 16 lbs dead lift is still very impressive. |
02-02-2013, 10:09 PM | #18 |
| Re: KMS K2 Free spool servo winch They lift more than 16lbs . Its what the jack that I use for testing weights. I fig that no scalers weighed more than 16lb so that was good enough,When run threw a bec with a 3 cell lipo they have more lifting power and speed as well .My tests are done at the minimum 6 cell 7.2 nickel metal hd battery.Using just a manual off on switch ,On my personal scaler I use a Heyok 4 amp relay winch controller ,tekin fxr, bec,.A freind of mine runs his K3 winch with a tekin fxr, 3 cell lipos ,He says it fast with lots of power,,
04-15-2013, 10:50 PM | #19 |
Ok scraped the frist prototype ,Heck buy the time I was done with it ,,it was scrape,,So I spent 600.00 dollars and bought some new tools ,At this time there is one on my work bench and hasnt broke yet ,It will dead lift 25 lbs ,,,,,Freespools very good ,still in the development stage 's ,,for a final freespool kit to release ,,,,It will use a 250oz or higher oz servo,,,KMS,,,
04-16-2013, 12:57 PM | #20 |
I'll take one and put some testing on it.
KMS K2 Free spool servo winch - Similar Threads | ||||
KMS servo winch, K2 ,K3,K3x2 | KMS | Electronics | 0 | 01-14-2013 08:31 AM |
Servo Winch Spool | MiniMorris | Electronics | 0 | 01-05-2013 12:43 PM |
Scaler Tech: How to make a servo winch spool... | justinart24 | Tools, and Procedures | 5 | 03-08-2012 11:09 AM |
