09-21-2013, 07:14 PM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: Yokota
| NQD Tear Into
I got one of these and this is my build thread for it! If it is in the wrong place please move it to where it should be. I will not be doing the paint I am having a good friend do the paint for me. It will have a Sea King 60a ESC with water cooling, and a 3900 kv 28mm can with water jacket, al cheapo mini servo with home brew pump mount plate, traxxas water proof rx case, 2200mah 3s pak, homebrew acrylic hatch with seal, homebrew watter pick up. SICRC flex shaft with impeller, SICRC impeller shaft bushing mod, SICRC intake grate, SICRC motor coupler. Sent from me using my DNA Last edited by BigJon; 09-27-2013 at 07:23 AM. |
09-23-2013, 07:40 AM | #2 |
| Re: NQD Tear Into |
09-23-2013, 12:29 PM | #3 |
What ya trying to say Ryan??! Saying my boat is going to sink. If either of our boats will be going to fast and run onto a iceberg (rock) I think it will be yours as you got the big pump in it! Sent from me using my DNA |
09-28-2013, 06:22 PM | #4 |
Going to pick this up tomorrow. Thank you bill for all the hard work! Also did some some homemade sealing on the ESC. Sent from me using my DNA |
09-28-2013, 07:09 PM | #5 |
| Re: NQD Tear Into
Should be cool to see it run. I helped a buddy last year by making some shaft couplings for his boat, it was neat to see the thing rip across the water and make a big wake!
09-28-2013, 08:15 PM | #6 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
I have an airboat build starting up. Ill stay tuned to this as well. Cant wait to see it come together. Thanks, LIK |
09-28-2013, 08:37 PM | #7 |
Newbie Join Date: Aug 2013 Location: USA
I have one too. Seaking 90a with a 2700Kv. It's like a mini revo of boats. They are a blast..... https://www.youtube.com/watch?v=wkyX...e_gdata_player |
10-01-2013, 08:06 AM | #8 |
Thanks BigSki! Lost have a link for that airboat? eurotiva nice vid! Quick update got the boat back. Been working on some homemade decals for the hull and been working on the pump. There was a hole in the scoop that I have been filling with CA I think I put to much in it as it is not drying. Also been smoothing out some rough spots in the pump. Also filling in the 5th bolt hole for the servo plate with a ca patch I am almost ready to start sanding. Sent from me using my DNA |
10-01-2013, 08:34 AM | #9 |
| Re: NQD Tear Into
Done yet? The water is waiting |
10-01-2013, 10:57 AM | #10 |
No the scoop patch is still wet and is not drying. I can't figure out what is going on. Sent from me using my DNA |
10-03-2013, 06:12 AM | #11 |
The ca I filled the scoop with was not setting up so I pulled it all out let the remainder dry than mixed up some epoxy and packed it full. Also finished grinding my homemade servo bracket. Need a clamp to attach it to the pump think I am going to use me elmers sealant so if I want to I can remove it. Tonight I am going to try to get the servo bracket attached and drill the scoop for the metal grate and attach the decals and clear the body. Sent from me using my DNA |
10-10-2013, 04:29 PM | #12 |
I have made quite a bit of progress on my boat finished the servo mount and attached it to the pump, drilled the metal grate holes in the pump and scoop, drilled the shaft hole for the brass bushing, glued in the pump, attached all the decals for clear coat. Sent from me using my DNA |
10-13-2013, 08:48 PM | #13 |
After a few hiccups it is ready to go. Other than the acrylic hatch. Already to play and no sun left in the day! Sent from me using my DNA |
10-26-2013, 08:45 AM | #14 |
Quarry Creeper Join Date: Jan 2009 Location: Truckee
| Re: NQD Tear Into
Don't forget the ramp boat for flat water fun.
10-26-2013, 12:38 PM | #15 |
Quarry Creeper Join Date: Apr 2013 Location: Upstate
| Re: NQD Tear Into
That is one sick pic lol!
10-26-2013, 12:54 PM | #16 |
Quarry Creeper Join Date: Jan 2008 Location: Granite Falls, WA
| Re: NQD Tear Into
watchin this one. ive got one also. took it apart cause it sank the first few times out and wanted to mod it. no im gonna have to and make a trailer for my tf2.
02-08-2015, 07:23 PM | #17 |
Quarry Creeper Join Date: Jan 2007 Location: HAY CAPITOL OF THE WORLD!!!!! weeeeeeeeee
| Re: NQD Tear Into |
NQD Tear Into - Similar Threads | ||||
Nqd jet boat | ROLANDROCKSHOP | Non Crawler RC's | 37 | 05-21-2017 12:06 AM |
