Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: Dingo drive shaft upgrade
Old 05-11-2014, 11:59 AM   #1
Default Dingo drive shaft upgrade
Ok so I broke my first part on my dingo today the rear driveshaft pin broke the part that makes the ujoint part if the w8 drive shaft I am running a small lift and 2.2 so when I get to full articulation ther is a small amount of binding and I am wanting a drive shaft that can handle sharp drive line angles and was wondering if the junfac drive shafts or the mip drive shafts would be better for my truck I am very limited on funds so I only want to buy drive shafts once the stocks lasted me over 2 years
1santaever is offline   Reply With Quote
Old 05-11-2014, 01:12 PM   #2
Default Re: Dingo drive shaft upgrade
Axial Racing - WB8 Universal Joint Rebuild Kit (2pcs)
The reason why you have binding is probably due to the lift. Either take off the lift or adjust your upper links to get a better pinion angle.
Lentsnh2012 is offline   Reply With Quote
Old 05-11-2014, 01:56 PM   #3
I under stand why I have the binding I run full droop on my scx10 no springs the binding is not the issue I am looking for an upgrade for reliability not because of binding but thanks for the suggestion
Old 05-11-2014, 02:02 PM   #4
Mip
boisetrucker is offline   Reply With Quote
Old 05-11-2014, 02:27 PM   #5
Is that what you run or are they just better
Old 05-11-2014, 02:41 PM   #6
If you're not running a high powered motor or really stressing the driveshafts too much, another set of WB8s will treat you fine. You said it yourself that your current set lasted you 2 years.
Old 05-11-2014, 04:05 PM   #7
Ok so I plan on rebuilding my stock drive shafts and keeping them for spares for my other scx10 so I want to upgrade the ones on my dingo to get rid of the little bit of binding I have at full extension due to longer shocks and a lift kit and longer links won't do it and I'm not taking the lift off because than I won't be able to use the truck at all the wheels and tires won't fit and I don't want to hack up my body here is how it sits
I also have weight in the front tires and tend
Dingo drive shaft upgrade - Similar Threads
Cheap Stock drive shaft upgrade sidehiller Axial Wraith 39 03-22-2013 09:42 PM
2 speed trans w/ drive shaft upgrade 40 grit Axial Wraith 10 10-31-2012 04:21 PM
Looking for drive shaft upgrade on TF2 Lex07 RC4WD Trail Finder 2 15 10-27-2012 09:09 AM
scx10 drive shaft upgrade? Physical Terrorist Axial SCX-10 5 02-23-2011 02:57 AM
Traxxas Jato drive shaft upgrade !!!!!!! Joat Tamiya CR-01 9 08-03-2008 10:39 PM
