Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: RC4WD's new v8 motor and transmission
Old 08-27-2014, 05:58 PM   #41
PapaGriz Yo
Grizzly4x4's Avatar
Default Re: RC4WD's new v8 motor and transmission
Originally Posted by Katan View Post
Yes the block holds 540 sized motors inside. Everything on the motor is a separate piece like a real engine. The engine unit is very similar in size to the old Parma 1/10 V8 engine model.
Perfect!!
Grizzly4x4 is offline   Reply With Quote
Old 08-29-2014, 10:16 PM   #42
I want I want I want ...... Pre order list or rouh eta yet???
The only downside I see is motor cooling. The styrene engine I use has a fan in intake plenum and blows out the exhaust ports to cool the motor so I'm hoping I'll be able to convert the air cleaner in some way to help with that.. Anyway awesome looking product so far and I can only hope we see a married t case and not a coupler to the hammer as I'm thinking it will be...
-Dan
sickcivic95 is offline   Reply With Quote
Old 08-30-2014, 09:19 AM   #43
Unhappy Re: RC4WD's new v8 motor and transmission
-Dan
couldn't agree more. At least the fracture motor was married. (and the case could be clocked) And total silence from those in the know about this specific issue/ question.
L.R.
LoneRanger is offline   Reply With Quote
Old 08-30-2014, 09:25 AM   #44
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
-Dan
Cooling may not be an issue , the entire block is aluminum and can pull heat fast if there isn't too much air inside.
JohnRobHolmes is offline   Reply With Quote
Old 08-30-2014, 09:29 AM   #45
Very true I wasn't thinking about it being like a "heat sink" as Long as the motor is making good contact with the block it should work great, add a little hx paste to help the heat transfer and done. I'd only worry if it's not making contact at all then the small bit of air will hear up and act as a convection oven......
--Dan
Old 09-02-2014, 02:51 PM   #46
I guess a 540 motor wouldn't fit in a 10 scale 22R. Then again a 22R wouldn't turn the tires we put on them at real scale. Slick looking chunk of aluminum.... I like it.... I like it a lot.
DRW-FJ40 is offline   Reply With Quote
Old 09-02-2014, 02:57 PM   #47
Wouldn't have to fit inside, can mount on top for all I care. And I have faith that the 22R would turn 1.9s with enough gear reduction if need be.
http://www.fourwheeler.com/top-truck...toyota-tacoma/
tokdl is offline   Reply With Quote
Old 09-02-2014, 06:42 PM   #48
Awesome. Just awesome.
Would look amazing in a custom build too.
KillerBlackbird is offline   Reply With Quote
Old 09-02-2014, 07:24 PM   #49
Just add a couple more transfer cases and you'll be fine.
pardonmyn00b is offline   Reply With Quote
Old 09-08-2014, 09:36 AM   #50
Bigger Battery
Dready is offline   Reply With Quote
Old 09-08-2014, 12:26 PM   #51
I would love to see more detailed pictures, more specifically, how the motor is mounted in the block.
Lentsnh2012 is offline   Reply With Quote
Old 09-08-2014, 03:48 PM   #52
I would like ANY info at all on this motor/ trans. A little birdy told me this may be released in a month- fyi
L.R.
Old 09-10-2014, 09:10 AM   #53
That looks awesome, but I didn't see if it is brushed or brushless. Anyone know?
-bjb- is offline   Reply With Quote
Old 09-10-2014, 09:45 AM   #54
This might help if you haven't seen it yet.
https://www.youtube.com/watch?v=Su0p...jLhFglk0HTM6Hw
Super is offline   Reply With Quote
Old 09-10-2014, 10:11 AM   #55
It's whatever electric motor you put in it.
Old 09-10-2014, 02:59 PM   #56
motor talk starts somewhere around the 13 minute mark.
L.R.
Old 09-10-2014, 08:23 PM   #57
Also, was thinking for those who did want to paint it. You could probably just partially thread in some screws into all of the threaded holes and paint it Chevy org. or what ever color. Then remove the screws as not to cake them with paint, or fill the holes with paint. Just an idea I was thinking of.
Old 09-13-2014, 05:51 PM   #58
Very cool!
2 questions though.
First, having the motor sealed up inside, would this help in making a sensored motor to be "water resistant", second, whens the diesel coming out?
bryco13 is offline   Reply With Quote
Old 09-13-2014, 05:57 PM   #59
Originally Posted by bryco13 View Post
Very cool!
2 questions though.
It is not "sealed" There are several openings that will always be open.
I like your second question...
Rckcrwlr is offline   Reply With Quote
Old 09-13-2014, 06:56 PM   #60
Silicone and shoe goo are cheap. I'll make mini gaskets.
RC4WD's new v8 motor and transmission - Similar Threads
RC4WD R2 Transmission/Motor Combo CruisinMT General Scale Talk 12 03-07-2012 06:16 PM
