Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: Steering link problem
Old 12-30-2018, 08:54 AM   #1
Default Steering link problem
Hi guys, I found out that my venture front steering link is 'rubbing' the front-left tyre. I had some run out of the box and notice this. Not sure why this is happening to my venture. The car is shaking when turn left and right in full speed. My tyre having a circle scratches.
Did anyone have the same problem as well?
https://ibb.co/xhjXL9m
https://ibb.co/znmdwvT
https://ibb.co/B6dzYCk
lexjean is offline   Reply With Quote
Old 12-30-2018, 02:15 PM   #2
Default Re: Steering link problem
Looks like the wheel spacer is to thin, take the wheel off and give us a better pix, and one from the top of the assy.
Corey99Z28 is offline   Reply With Quote
Old 12-30-2018, 03:58 PM   #3
I had this issue when I put on larger tires (pit bull rock beasts). I ordered a set of 7mm offset aluminum wheel hexes. They were about 8$ and it pushes out the wheel enough to prevent rubbing.
flat6extreme is offline   Reply With Quote
Old 12-31-2018, 12:14 AM   #4
Here is the pic.
I think getting a 1mm or 2mm wheel spacer will fix this.
Steering link problem - Similar Threads
SSD V2 Steering Link vs. VP / Incision Steering Link Drm31078 Axial RR10 Bomber 26 02-03-2017 08:32 PM
Steering/Alignment Problem After Install RPM Steering Knuckles? Barzan724 Newbie General 2 01-21-2016 06:32 PM
Pan hard steering link problem Troublekitty Axial Wraith 15 11-20-2014 08:03 PM
