Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: GPM center drive shaft
Old 05-27-2019, 05:31 PM   #1
Default GPM center drive shaft
Anyone use the GPM center drive shaft that connects the transfer case to the slipper clutch? If so, I'm curious how the spring tension is maintained to make the slipper clutch tighten/loose. Can't find a good picture, description, or review on line. Or should I just stick with the drive cups and the dogbone? Anyone know of a third option I am unaware of? Any help is appreciated 😊
Delta5Actual is offline   Reply With Quote
Old 05-28-2019, 04:45 AM   #2
Default Re: GPM center drive shaft
The stock drive shaft is fine in my opinion. There isn't and variation in angle while driving as you get with axle driveshafts. Dogbones are bad on steering shafts as they limit the turn angle is the reason for cvd's or universals. I lock my slipper anyway just by winding the spring tension up tight anyway.
M1tch is offline   Reply With Quote
GPM center drive shaft - Similar Threads
HR rear center drive shaft? twisted Axial Yeti 1 11-19-2016 09:51 PM
Gpm drive shaft Kx450 Axial Yeti XL 5 12-16-2015 08:24 PM
broke a center drive shaft dodgesavageone Venom Creeper 2 03-02-2011 07:47 PM
center drive shaft The Mechanic Newbie General 1 02-17-2011 03:05 PM
