Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: Caster question
Old 11-01-2019, 09:18 PM   #1
Default Caster question
I installed the Cralwers Central links as soon as I got my Venture. Would adjusting the length of the lower links via unscrewing the rod end add caster to the front? In my head it makes sense but I may be way off and am reaching out to the crawler community for advice. Thanks!
jason02ws6 is offline   Reply With Quote
Old 11-02-2019, 12:21 AM   #2
Default Re: Caster question
I see those links are solid stainless steel. If you want to increase the length it would be best to get longer rod ends. I got more caster on my SBK by shortening the upper link by 4mm. I used Vaterra Ascender links with spacer to do this.
The Ascender parts.
Resulting camber.
M1tch is offline   Reply With Quote
Old 11-02-2019, 02:16 AM   #3
The Ascender parts.
Resulting camber.
Do you happen to have the eye to eye length of that upper link you made?
Old 11-02-2019, 02:29 AM   #4
I'm not sure but I used the stock Venture ends and the link is 100mm. Can't measure it as not at home until later. It's 4mm shorter than stock is all I remember.
Old 11-02-2019, 02:32 AM   #5
Thanks. I might dig through my parts bin to find something that’s close.
Caster question - Similar Threads
Too much caster? jason02ws6 Axial SCX10 II 7 08-24-2018 11:14 AM
New to the Yeti...caster block/knuckle question. jamr1130 Axial Yeti 5 03-22-2016 11:46 AM
caster ?'s ax10tn Axial XR10 9 05-01-2012 05:25 PM
caster question??????????? gatecreeper Axial AX-10 Scorpion 5 03-23-2011 09:08 PM
Question about front & rear caster on a custom rock-crawler with 4-wheel steering... Chadworkz General Crawlers 6 11-22-2008 11:44 PM
