Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: Stupid screw size
Old 12-10-2019, 01:03 PM   #1
Default Stupid screw size
So I thought I'd paint my diff covers, unscrewing them I noticed that they were pretty rounded so no biggy I have tonnes of stainless m3 that would fit. Ha, the screws ar 2.4mm thick ffs
crazee horse is offline   Reply With Quote
Old 12-10-2019, 07:52 PM   #2
Default Re: Stupid screw size
I've also wondered about that weird size. What were they thinking? More genuine screw sales maybe?
Not really a big problem. Simply replace them with 2.5mm screws. They will be a little stiffer the first time you put them in, less stiff than when you're building a kit and threading screws for the first time. I've been told the stainless screw kits use 2.5mm to replace them as well.
Sent from my LG-H870DS using Tapatalk
bbrigg is offline   Reply With Quote
Old 12-10-2019, 08:17 PM   #3
Tiny Truck Hoarder
HumboldtEF's Avatar
it is listed as 2.5mmx25mm in the manual.
It is very common for diff covers to be odd though many are 2.6mm
HumboldtEF is offline   Reply With Quote
Old 12-12-2019, 05:13 PM   #4
Well they were a pain to get out as a few stones had damaged 2 of the hexes so out with the dremel to make a slot! In two years only the servo has been changed, she's getting a good service this weekend both diffs stripped cleaned and greased up ��
Old 12-17-2019, 08:05 PM   #5
What bugs me is that I can't seem to find longer bolts so I can use nuts on the back side of the upper link mounts.
meatmonkey is offline   Reply With Quote
Old 12-17-2019, 08:18 PM   #6
Tiny Truck Hoarder
HumboldtEF's Avatar
Another option to consider is the metal upper link mounts. These screws would thread into this metal piece. GPM makes some and I though someone else did too but I cant seem to find any others.
https://www.gpmparts.com/venture-toy...a-p-13184.html
EDIT: now I'm looking for a rear mount, I see Hot Racing makes one but I only see it with their link set https://www.amainhobbies.com/hot-rac...3plm01/p765919
Or you could try these screws, 2.5mm x 30mm https://www.amainhobbies.com/oxy-hel...0cs-10/p982581
I find Amain has a pretty big selection of screws.
Old 12-18-2019, 09:06 PM   #7
Thanks for the link to the bolts. I don't think I require an aluminum mount, but I sure would feel better about having metal threads from the extra nuts.
Stupid screw size - Similar Threads
Screw size Frank211 Newbie General 10 12-23-2017 04:15 PM
Screw size Slowsteve Axial Wraith 2 08-31-2011 03:29 PM
Need BL screw size? Krakker Losi Mini-Rock Crawler 3 02-09-2010 12:56 PM
screw size gas EnRoute Berg 3 03-27-2009 08:23 AM
Screw size? BlueMonster General Crawlers 5 01-09-2006 06:31 PM
