Thread: write up,for mod for putting ring and pion from a e savage in wheely king
Old 09-26-2008, 10:21 PM   #1
Talking write up,for mod for putting ring and pion from a e savage in wheely king
Well I’m starting a new right up on how to mod the ring and pion gears for an e savage to put in a wheely king. Go sick of stripping the old stock one. So will have it up in a few days. If you have any question in the mean time hit me up.
Thanks’ thevulgarcowboy
thevulgarcowboy is offline   Reply With Quote
Old 09-27-2008, 02:48 PM   #2
I´m watching
Arent they just a drop in replacement ?
SnoopMaxx is offline   Reply With Quote
Old 09-27-2008, 05:04 PM   #3
chris4207's Avatar
I'd like to see how they fit as well.
They do look like they are drop in dont they, I had to go look at them again. Hpi has the Hardend ones for the Nitro RS4 mt listed as option parts. I wonder how many different sets are drop in.
chris4207 is offline   Reply With Quote
Old 09-27-2008, 06:56 PM   #4
The ring gear bolts right in. but the pion gear you need to shave a little of where the e clip goes in the top. Or do what I’m doing, I’m beveling the inner face if the gear. 1st less material removed and not a lot of heat buildup in the part to change the temper of the steal
ps will have pics up in a few days
Old 09-27-2008, 09:31 PM   #5
So.......drop in ring gear, clamp pinion in drill press, drill down a little with a large drill bit to bevel, install pinion, the end?
I should do a writeup of how I installed Pede shafts and yokes using stock parts without compromising strength.....
HndsWthtShdws is offline   Reply With Quote
Old 09-27-2008, 09:43 PM   #6
that would be nice
grizz is offline   Reply With Quote
Old 09-28-2008, 09:05 AM   #7
I have had these nitro rs4 diff´s for little over a week now and I havent had time to bolt them in yet
they are the 36T/14T gears so they will lower the gear ratio = more speed
Old 09-29-2008, 11:21 AM   #8
I'd like to read this too. That is the one area where I am having trouble with my WK.
Maggster is offline   Reply With Quote
Old 09-29-2008, 04:05 PM   #9
Are you guys still using those stock axle screws? That might be why your stripping diffs. Get rid of the four screws around the pumpkin and replace them with four 3mmx35 SHCS and four nylocks.
Old 09-29-2008, 07:19 PM   #10
I did replace mine with threaded rod. I don't know if its a bad driver, or the fact that I am still using the big ole mud thrashers, but I still get an occassional diff click. I shimmed them pretty tight, but it still clicks once in a while.
Old 09-30-2008, 02:24 PM   #11
Gah, the axles rounded mine out, the back ones are clicking whenever I gas it. Hurry up with this writeup bro
coolkidjf7 is offline   Reply With Quote
Old 10-03-2008, 01:59 PM   #12
will have up by monday or tuesday. had a death in the family
Old 10-03-2008, 02:03 PM   #13
Sorry to hear that, take your time.
Old 11-04-2008, 04:55 PM   #14
any updates i really need to upgrade my diffs
execelon is offline   Reply With Quote
Old 11-04-2008, 05:21 PM   #15
Will have up in a day or to, jest go back in town. when your dad dies thare a lot i mean a lot of lose end. but sorry for the long time befor postings
Old 11-20-2008, 06:50 PM   #16
UPDATES? Mine has the death click as well. Looking for a good remedy.
karlos is online now   Reply With Quote
Old 11-20-2008, 07:09 PM   #17
i too would like to see this written up. Hurry up already :P
In for some updates.
boostamante is offline   Reply With Quote
Old 11-20-2008, 07:42 PM   #18
Gold Star Baby!
rottenbelly's Avatar
Shim,shim ,shim them and they wont click. i have aluminum tranny gears, strc rear lock outs ,aluminum hexs, and with the pinions shimmed the only thing i have problems with is breaking front axles.
rottenbelly is offline   Reply With Quote
Old 11-20-2008, 08:15 PM   #19
http://cgi.ebay.com/HPI-Final-Gear-S...QQcmdZViewItem
this is what i went with and i couldn't be happier.. no more clicky clicky for me!
Old 12-16-2008, 08:18 PM   #20
Default update
side by side new to old. new on left, old on the right
clamp in to vice or vicsrips.( NOT on the teeth)
dremil bit I used
grind center to u gind down to flat spot ware E clip goes.
befor grind.
after grind(1 on the left/ a nice dish shape)
a quick tip using the drive shaft as a handle makes putting the E clp in ezer
sorry for the bad pic. thare on my cell phone. my lil 1 thought my camera needed a bath. so did this mod on my brothers. the ring gear bolts in the stock place with no mods and rest of the axle goes back together jest like stock.
ps you might have to reshim the hole set up.,
