05-07-2010, 02:08 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Burbank CA
| WK Axles on K2 Chassis
Has anyone ever made a scaler using a K2 chassis and WK Axles? I have some axles laying around and a K2 chassis but I just can't wrap my head around how to mount the WK trans since it has to be upright. I can figure out the links and the servo mounts... If anyone has done this sort of build before please put up some pics...I need jumpstart for ideas |
05-07-2010, 02:16 PM | #2 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
See this post. questions about scale chassis |
05-07-2010, 02:19 PM | #3 | |
Are you using the same motor mount plate from HPI? Would it be possible to get details on how you mounted the trans? Thanks again | |
05-07-2010, 03:21 PM | #4 | |
1st Attempt at a scratch built rig! I just cut a skid out of delrin, but you could use some cutting board material from wal mart also. The motor plate is a clocked motor plate that i got from here. http://www.eastendmachining.com/crkiwhkiclmo.html You do have to trim the post off of one side of the tranny and do a little dremal work to run a small pinion. I was able to run a 16 t without to much dremal work but i wanted to run a 14 so i took alittle off the case. Hope that helps, If not i will try to answer any other questions. | |
05-07-2010, 05:46 PM | #5 |
If you don't have to use a wm tranny get a stampede tranny. They fit well and are very cheap now 15-25$ and you. Can use maxx shafts too
05-07-2010, 05:54 PM | #6 | |
I still have to figure out what I'm going to base this build on. Definitely something with a SWB...sami perhaps. Thanks for the info BTW rottenbelly! | |
