Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Longer Driveshafts
Old 09-16-2012, 06:38 AM   #1
Default Longer Driveshafts
I have looked around and found that some of the Traxxas shafts will work, but am not sure if I have the correct part number/item description. If I use Traxxas shafts, do I need to get the output yokes also or will the work with the HPI ones? These are the items I have found, can I get verification on which to go with?
Really hoping these will work with HPI yokes...give me a spares to play around with in the future:
TowerHobbies.com | TRA1953 1953 Traxxas Long Truck 1/2 Shaft Pro Pak (6)
Are these different than the first link?
TowerHobbies.com | TRA4951X 4951X Traxxas Half Shafts Long T-Maxx (2)
TowerHobbies.com | TRA4928X 4928X Traxxas Diff Output Yokes w/Screw Yoke Pins 2.5 (2)
rockhound is offline   Reply With Quote
Old 09-16-2012, 07:07 AM   #2
Default Re: Longer Driveshafts
The first link you posted is for the Stampede. They're great for scale trucks but won't hold up on a WK. What you need are the T/E- Maxx shafts, much beefier . If I remember correctly, the Maxx shaft U-joint ball will fit the stock HPI yokes, but it will be snug.
TrailDawg362 is offline   Reply With Quote
Old 09-16-2012, 10:36 AM   #3
MSB
the stock yolks will work with maxx shafts, you don't "have" to replace those, fyi. You can, don't have to, even with revo shafts.
MSB is offline   Reply With Quote
Old 10-08-2012, 05:53 PM   #4
RCP CRAWLERS
ZoSo's Avatar
this is what you need
Traxxas*T/E*Maxx**Half...
these are for the WK axles 6mm
Traxxas*T/E*Maxx*diff...
you can use these for the axial tranny outputs 5mm
TRAXXAS*Transmission*Output...
but I would use these steel outputs with the holes for the axial tranny
Axial*Steel*output*Shaft...
the locking pins on the traxxas universals are very strong
they've been working on Rich's 12 lb 1/6th willys for years.
ZoSo is offline   Reply With Quote
Longer Driveshafts - Similar Threads
I need longer driveshafts where?? mtgrizzlymn Axial AX-10 Scorpion 1 04-21-2012 06:34 PM
longer driveshafts??? jetboat Losi Mini-Rock Crawler 12 08-26-2010 07:09 PM
Longer driveshafts? Coop980 Losi Mini-Rock Crawler 2 10-24-2009 07:03 PM
Longer highlift driveshafts sierradmax General Crawlers 1 10-02-2008 09:44 PM
longer driveshafts bradahb General Crawlers 3 07-31-2007 02:58 PM
