Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: crawler king/Moms' cutting board
Old 01-27-2015, 09:01 PM   #1
Default crawler king/Moms' cutting board
so I had a wheely king that I had done some modding to, and then ended up tearing down and it turned into spare parts. I decided to make it a project this week, and came up with a design for the frame, and happened to have a Pro-Line Tuber chassis/body for an AX-10. It looks a little rough and needs to be refined and tweaked, but I think it came out pretty good for a rough draft.
I'm running 1.9's with Pro-Line flat irons on tamiya wheels, a 20t hpi brushed motor mated to a level3rc flipped motor mount, Hobbyking brushed esc w/drag brake and a traxxas 2075 servo for now to see how it all works. I'm gonna run it at the local gsrcc scale comp this weekend to see what I need to do next.
makya is offline   Reply With Quote
Old 01-28-2015, 06:05 AM   #2
Default Re: crawler king/Moms' cutting board
Nice! I like the overall design. Not bad at all for a rough draft
OSRC is offline   Reply With Quote
Old 01-28-2015, 12:39 PM   #3
Thanks, after seeing your CR-01 and CC-01 builds, that's a big compliment
Here's the side pic with the roof, hood, and side panels on. I haven't figured out how I want to mount the rear decklid yet, and after a quick run this morning, I need to move the rear axle back a bit more and tidy up the wiring.
when I re-do the chassis rails (I picked up another cutting board yesterday), I think I'll try to integrate the front shock mounts into the rails.
the other problem I've got is that it only weighs 4 lbs 3oz with 2oz of weight in each front tire and a small 2200mah 2s lipo in it, so I'm having a hard time finding soft enough springs for it I'm probably going to need different shocks as well.
Old 02-07-2015, 06:15 AM   #4
do you have a problem with bump steer at all
fullsizecrawler is offline   Reply With Quote
Old 02-07-2015, 05:43 PM   #5
I haven't, but that's mostly because the springs are a little too stiff, so it isn't flexing as much as I'd like. I will be adding a panhard bar to it hopefully this weekend, along with replacing a few parts I broke over last weekend at the GSRCC #18 competition (there's pics and video of the event in the competitions forum)
Old 02-04-2016, 09:04 AM   #6
So.......
this sat a lot longer than I thought it would. I made a new main tube out of brake line, and I need to make the brackets still, but I think it came out well so far
I also got the overdrive set for the front, and I made some pvc lockouts for the rear
WP_20160203_001 by makya9, on Flickr
WP_20160203_002 by makya9, on Flickr
WP_20160203_003 by makya9, on Flickr
Old 02-06-2016, 09:22 PM   #7
I made a little more progress today, I made the front mounts to tie in to the ProLine Tuber body, and the transmission mounts on the passenger side of the chassis.
WP_20160206_007 by makya9, on Flickr
I need to clean up the welds, and I picked up some brazing rod today to some some of the more intricate work.
body off shot:
WP_20160206_009 by makya9, on Flickr
I also put the overdrive set in the front axle, and installed the lockouts on the rear. I can't wait to get this thing working again
Old 02-09-2016, 12:05 PM   #8
a few notes:
I lengthened the front and rear links to compensate for the COG, with the new chassis and front OD, I can hopefully shorten the wheelbase a little, and place the battery down low.
The new chassis will also have room for a driver, so it will be legal for U4RC.
I am still using the ProLine Tuber chassis for the body to save weight up top.
hopefully, with the battery low, I can run a chassis mounted servo, without too much of a shift in COG.
Old 02-20-2016, 08:09 PM   #9
a rough mock up of what I have so far:
3 link with panhard, front and rear
cutting board belly pan/bottom link mount
the steering servo mount is temporarily styrene.
I still need to figure out the battery mount, probably shorten the front links, make a winch mount, fender wells, interior and transmission housing cover.
WP_20160220_002 by makya9, on Flickr
WP_20160220_004 by makya9, on Flickr
WP_20160220_005 by makya9, on Flickr
WP_20160220_003 by makya9, on Flickr
crawler king/Moms' cutting board - Similar Threads
Back to the Cutting Board poomwah Formula Offroad 9 02-14-2013 07:47 AM
cutting board? bigblazerboy Newbie General 10 10-10-2007 01:48 PM
cutting board material ? twisted Tools, and Procedures 13 01-12-2007 09:52 PM
