05-08-2007, 02:15 PM | #61 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
X2, I work in a LHS and I try to build things with stuff we have in stock instead of buying parts online or major fabbing for that reason. I think the most tool intesive mod I've done is the body mounts for my Pede with the HPI Ram ST/MT body. I used a Dremel but it could be done with a miter box and hand saw.
05-28-2007, 10:34 AM | #62 |
Rock Crawler Join Date: Apr 2007 Location: St. John's
BJoe: A while back you asked about an aluminum bellcrank used by themerc64. I fabbed a bellcrank out of 1/8 aluminum plate and I put a bushing in as well. You can't see the bushing but its a piece of brakeline. There is no binding whatsosver plus I added a nylon washer under the bellcrank for futher reduction in friction and slop. It works great. To any who are wondering, I switched the bellcrank to the other side of the diff because when I did the chassis reversal I opted not to move the servo from its stock position. (I will be mounting the servo over the axle soon enough and will make the shift at that point). I fabbed a new bellcrank mount from aluminum and bolted it to the diff case. It was actually quite easy. Here is a picture: Sean |
06-24-2007, 10:15 PM | #63 |
Newbie Join Date: Jun 2007 Location: port st. joe
| Rear Steer
Where Did Some Of The Guys Buy The Rear Sterring Servo Mount That Fits On The Axle? Thanks
07-09-2007, 04:53 PM | #64 |
Newbie Join Date: Jun 2007 Location: Littleton
| Pinion Gear Change?
Getting the parts needed to make my WK a crawler and noticed on the list that starts the thread there is no pinion gear change. Is this correct? Other threads show a 96t spur (this list has a 93t) and a 15t pinion. No change needed for pinion gear? Thanks |
07-09-2007, 09:49 PM | #65 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
vinny1957, I had to leave something to the imagination of others. I am running a 12x93 and a Integy 55 turn. Remember this... 1 on the pinion is equal to 3 on the spur. |
07-10-2007, 07:55 AM | #66 |
Thanks!
07-15-2007, 04:49 AM | #67 |
Quarry Creeper Join Date: Mar 2007 Location: 530
Where did you get the bearings that cheap?
07-15-2007, 05:48 AM | #68 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
Good thread, I am looking at getting a wk for a larger trail truck. I like that for the price its rtr, and won't take much to build it to run how I want. HPI has a winner here.
07-15-2007, 10:56 AM | #69 |
I like that bellcrank set up you've got there Sean, does that mount flex as much as the stock one?
07-15-2007, 07:16 PM | #70 |
I've since moved onto an axle mounted servo but when I did use the aluminum bellcrank, I had no flex. Sean |
08-22-2007, 10:19 PM | #71 | |
Rock Stacker Join Date: Feb 2007 Location: canada, manioba,winnipeg
08-22-2007, 10:37 PM | #72 |
Do what and where? I really need to post some updates of my WK. Been too busy playing with it!
08-25-2007, 04:35 PM | #73 |
Newbie Join Date: Jul 2007 Location: houston
good idea with the lower links but what about your trany
