04-17-2007, 10:12 PM | #21 |
Pebble Pounder Join Date: Apr 2007 Location: Glendale, AZ
04-17-2007, 10:32 PM | #22 | |
I know you can not tell much from this photo, but it wasn't long before it tumbled over. (might of had something to do with the drop off) I did notice that the COG is decent if I can keep the wheel speed down (crawl'in). Under full compression and giving it throttle on any type of decent side angle, I can get it to tip, but not roll. I think it could use some stiffer springs and lowering the COG can hurt. The suspension seems snappy. It is running about half droop. I did not notice very much side wall rollover. I did not use the talked about star cut n the foams, I just shaved them down about a 1/3rd. A burp of the throttle, pushed it over on this one. | |
