| | #1 |
| Pebble Pounder Join Date: Apr 2007 Location: Waddell, AZ
| Here is my first atempt at building a crawler. I picked the wheely king for the look of the axles. What I did not realize is the challenge of mounting these axles and gaining ground clearance. I made many attemps at custom brackets and after about 4 tries I ended up with this. I fliped the stock clamps upside down and sut off the tabs (old shock tabs). I cut out some sheet metal and drilled and bent them to fit on the axle straps. This put the lower link mounts on the inside of the axle housing. This seemd to be good except the drive shaft u-joint was below the lower links. I made a slight bend in the lower links to help protect the shafts. I liked the WK upper triangulated links so I made some custom ones. I fought the steering servo mount as most people are. I used some sheet metal again and created a mount that bolts the shock mounts. Seems to work pretty good. I found that the REVO shafts worked almost perfect for the new drive shafts, just a small amount of shaving to make the fit. I locked the diff's by filing out the two inner gears holes to a square shape and using some 1/8" solid sqaure stock. Worked great with some extra filing of the shaft ends to fit into the cups. It took about 4 attempts to get it this far. Alot of trial and error. Here it is WK axles - locked WK trans - 96 spur - 21 pinion WK shocks - 70 weight oil 55 turn motor LRP ESC 2.2 MOAB's HPI Spike wheels Proline F150 body ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Mar 2007 Location: sydney Australaia
| Sweeeeeeeeet |
| | #3 |
| Quarry Creeper Join Date: Mar 2007 Location: Syracuse
| Wow that looks awesome. How did you mount the tranny? |
| | #4 |
| | #5 |
| Rock Crawler Join Date: Jan 2007 Location: Midway
| Can you take a pic of the front axle and servo mount area from the front. I would like to have a better look. Interesting? Also does the battery move back into the motor as the front axle raises/shocks compress at same time. Seems it would push motor/servo some as I see no extra space. Nice truck |
| | #6 |
| Quarry Creeper Join Date: Jan 2006 Location: colchester
| it almost looks like it would just slide in underneath the motor. seems like it is just at the right height and that as the front end goes up the back side of the batt pack would angle down a little more also to allow for more clearence. can you see what im saying? |
| | #7 |
| Newbie Join Date: Jul 2006 Location: On the Rocks
| Sweet rig! Love the new ideas for suspension mounts. |
| | #8 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| You need bigger pics. Can't quite see the molecular content of the screws. |
| | #9 |
| ROFLMAO^^^^ |
| | #10 | |
The battery sits on a plate with the end bent up so it clears the backside of the servo. It is tight, but, clear. The other end is clear from the gear box. The wire may rub some. When the suspension goes through the full motion, there is no binding. The battery does not move much because of the velcro patch. No problems yet.? Take a look. I removed the side of the chassis so you can see that it is on a simple pivot. Also, the other end of the batttery tray is bent at 90 degrees to keep the battery from bumping the back of the servo. ![]() There is room for the wire leads when the battery is installed. ![]() The front of the battery has some clearance. ![]() Here is the servo mount. It leaves room to get to the upper link axle screw. ![]() I appreciate your comments. Thanks | |
| | #11 |
| | #12 |
| Newbie Join Date: Dec 2006 Location: Knox,TN
| That is awesome, Nice fab work! I am definitely building a WK axle machine next. I just can't decide if I want it to be a crawler or a trail/mud rig. |
| | #13 | |
Thanks for the comments. | |
| | #14 |
| Quarry Creeper Join Date: Apr 2006 Location: the creek
| Great build! the WK looks like a lot of fun... I want to make a trail rig for my son out of a WK... just need him to pass a "test" and my wife to not pay attention to the bank account... rofl! Last edited by gopher; 04-06-2007 at 02:51 PM. Reason: spelling... still mistakes I am sure |
| | #15 |
| | #16 |
| RCC Addict Join Date: Feb 2005 Location: Guam
| that is a nice build. hopefully, i will get me a wk soon;) |
| | #17 |
| Newbie Join Date: Aug 2006 Location: peterorough
| Nice job on the frame, I'm going to use Reign Products K2-3S http://www.rcpcrawlers.com/chassis.htmlframe when I get my WK and some money for that matter. I really like the scale look of the wheel/tire/body combo |
| | #18 |
| RCC Addict Join Date: Aug 2005 Location: Akron
| wow that track width looks wide! I never payed attention to it on my WK. Maybe its because your body sits lower. Looks killer! |
| | #19 |
| Kdubb88, Nice truck!!! I like the servo mount being different. I was concerned about the battery pack riding back into the motor area when both front shocks compressed as in a drop or fall. But looks like there is room. What's it like on a side angle with the battery and motor that high. COG? Any problems rolling over. Also 4oz. of #8 plastic beads helps fill the tires and slows side wall rollover. Also helps COG. Still a very nice rig |
| | #20 | |
Thanks for the frame link. I just received my 4x4 WK today and I am thinking of making a leafer. That frame might work out good with the body I am going to use. | |
| Thread Tools | |
| Display Modes | |
