04-13-2007, 03:37 PM | #21 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
just mix up the jbweld, and pretend it's grease, then lube the gears with jb-weld then bolt the case back together, and don't lube the ring gear with the JB!
04-13-2007, 10:30 PM | #22 | |
Rock Crawler Join Date: Jan 2007 Location: Midway
04-13-2007, 11:36 PM | #23 |
There is a groove in the diffcup and the ring gear for o-rings just like an 1/8th scale nitro. The same ring and pinion and diffcup is used in the MT18SS, etc, so probably if you look at the exploded view of those trucks on HPI's site they probably show o-rings in there and give part numbers for them. However, you are kidding yourself if you think it will crawl for **** with thick silicone oil in the diffs...LOL!!! For the guy asking where to put the JB Weld...mix more than you think you'll need and then some...assemble the diff with this instead of grease and pack it full to the top. Then put the ring gear on and tighten the screws. I assemble it in the axle housing so that the side gears are all aligned properly for the axle shafts and every little bit I remove the axle shafts and wipe the excess JB Weld off them and use a tiny screwdriver and an X-Zacto knife to scrape the non-hardened stuff off the ring gear before it hardens. I put a light coating of Vaseline (on pancakes) on the ends of the axles so they dont' stick to the JB Weld as much. Last edited by Natedog; 04-13-2007 at 11:41 PM. |
04-14-2007, 10:28 AM | #24 |
Quarry Creeper Join Date: Nov 2004 Location: Mid TN
| No, it certainly isn't! I was initially going to try locking with a fluid, however I quickly realized that it simply would not work with this diff. That's when I resorted to jbweld. Now, interestingly enough these fluids I'm talking about work really well in nitro monster trucks, especially for racing.
04-19-2007, 10:35 AM | #25 |
Newbie Join Date: Apr 2007 Location: Boston
If you are going to be rock crawling do you want to lock both diffs also where to you get the jb weld?
04-19-2007, 10:39 AM | #26 |
Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
yes lock both... walmart or most auto parts stores
04-19-2007, 03:09 PM | #27 |
Rock Stacker Join Date: Mar 2007 Location: San Antonio
| YEAH,I used putty and the wheels aren't locked,Although it definately helps..I will try hot glue later,Right now I like the fact that I won't snap an axle as easily.Besides,I'm not competing with it.:-( LOL
