Thread: Locking diffs
Old 04-07-2007, 06:00 PM   #1
Default Locking diffs
Alright, I am tearing it all down to strech it out. What do you guys use to lock these diffs? I wish HPI made a spool
Project Dad is offline   Reply With Quote
Old 04-07-2007, 08:42 PM   #2
I used JB weld on mine. Worked well. Now if I only had a front diff...
cotharyus is offline   Reply With Quote
Old 04-09-2007, 12:00 AM   #3
i'm pretty sure you can add a third gear into the diff case to lock it up if you wanna be able to unlock the diff for any reson latter.
hdcustomizer is offline   Reply With Quote
Old 04-09-2007, 06:13 PM   #4
I don't think the "relocated 3rd gear" method will work with the WK. There are only 2 spiders, not 3 like the Tamiya. And the spiders are smaller then the side gears, so the space between gears isn't "just right" for cramming another gear in there.
swhenrik is offline   Reply With Quote
Old 04-09-2007, 07:28 PM   #5
I looked at a couple of options before I went with JB weld, including some presure tensive fluids. The problem is, these diffs aren't sealed, so anything that remains even slightly fluid stands a chance of escaping out into the axle and causing problems.
Old 04-09-2007, 09:58 PM   #6
Would silly putty work?
4x4dodge is offline   Reply With Quote
Old 04-09-2007, 10:18 PM   #7
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
If you want a locked diff, No.
It works like a limited slip, and that is in a TLT style with closer spaced gears. In a WK it would work even worse.
Just use the right stuff, JB or hot glue. I prefer hot glue.
Josh
Harley is online now   Reply With Quote
Old 04-09-2007, 10:25 PM   #8
.... and with hot glue, it is fairly easy to remove IF you ever want to undo it (like anyone would.)
Ramza is offline   Reply With Quote
Old 04-09-2007, 10:44 PM   #9
Oh well, it was just a thought
Ill probably hot glue mine then
Old 04-09-2007, 10:50 PM   #10
Well I ended up getting some silicone and filling up around the gears. It took longer for it to dry since it was not open to the air. I use silicone so I could remove it if I ever wanted to. Plus after it dries it is like rubber so It will give alittle.
Old 04-09-2007, 10:51 PM   #11
I just got my 4x4 today, and just hot glued the rear diff. I am waiting until the weekend to get all the stuff together for the stretch. I ran it stock and it seems like it will do fine after I lock it up and add some new tires.
lowblueranger is offline   Reply With Quote
Old 04-10-2007, 09:31 PM   #12
I tried the silicone in my rear diff when I first got my WK, and it broke down after a while. I ended up cleaning it all off and JB welding it.
lonewolf039 is offline   Reply With Quote
Old 04-11-2007, 02:02 AM   #13
Thanks for the heads up. Prolly just redo them during tuber build.
Old 04-11-2007, 01:44 PM   #14
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Curious.....has anyone ever unlocked a diff at a later date?
Jay
roktoy is offline   Reply With Quote
Old 04-11-2007, 05:24 PM   #15
Jay
Yes. Pressure tensive fluids can be drained, but again, you have to be able to seal the diff to use them. They are liquid and run out when static, but the minute you try to compress it or move something through it fast, they become essentially solid. I'm certain everyone can see the potential advantages of using a fluid like this in a diff. Dump it out, wash it off, grease it up, it's unlocked.
Old 04-12-2007, 01:37 PM   #16
Dirt Addict
roktoy's Avatar
Why did you decide you wanted it unlocked?
Jay
Old 04-13-2007, 02:22 PM   #17
Jay
Converting an electric street rig from dragster back to "streetrod". Not sure why you'd want to unlock the diff on a crawler
Old 04-13-2007, 02:35 PM   #18
will anyone show me how to lock it with jb-weld Please? or at least tell me where to put the jb-weld. thanks
I like pie is offline   Reply With Quote
Old 04-13-2007, 02:42 PM   #19
Post #6
locking diff's on "wk"
joemomma95 is offline   Reply With Quote
Old 04-13-2007, 03:37 PM   #20
thanks but I still dont see what exactly you do sorry for being a pain and all.
