09-03-2007, 12:38 AM | #61 |
Quarry Creeper Join Date: Jan 2007 Location: Italy
I have some questions: 1) The axi 2808 output shaft should be 4 mm, greater than most pinion holes. Are special pinions available ? Do you make the hole grater drilling it ? I think there is little material on few theeth pinion such as 9- 10th. 2) I'm using an esc with 5v 1 A BEC such as Mamba 25. Most times I have difficulties in turning the wheels and it seems it is due to lack of torque in the servo. It is a metal gear one so I suppose the lack of torque is due to lack of current. What are you using ? Do you have a separate battery pack for the radio ? 3) You promised to post a template. Where is it ? I' m impatient ! Many thanks Filippo |
09-04-2007, 10:33 PM | #62 |
Rock Stacker Join Date: Feb 2007 Location: Whitecourt
I pulled the motor shaft out and chucked it up in my drill press, then carefully filed it down to 1/8 inch to fit regular pinions. When I was running the Mamba 25 I was using the MPI regulator, now that I am using the Mamba Max, it has enough power to run the servo with out the regulator. For the motor template, here is a pic of mine, nothing fancy. I only used the AXI because I had one sitting around from one of my 3D planes. There are lots of drop in motors out now, no modding required. |
09-20-2007, 10:30 PM | #63 |
Ok, I am now running my old handwound 55 turn speedgems motor, same gearing and battery. It is a little slower and wimpier, but has incredibly smooth low end throttle. I went on a road trip to BC, and ran a bunch of battery packs through it on some real awesome rocks. The truck is handling great and I am very impressed, it actually outclimbed my super on the slippery rocks. The bigger, wider tires on the super just don't get the traction that the cut mashers do. Also, I haven't spent as much time dialing in my super as I have my tuber. I ran it hard the whole time with many rollovers and hard hits, and the only thing I tweeked was a front shock mount. The front diff is skipping a little, as it is well worn, so I will be changing it out for the hardened gears soon. All in all, I am real happy with the handling now. Here is the vid. http://homepage.mac.com/lonewolf039/...Theater10.html BTW, I simply attached the camera to my transmitter, and took video while driving, so excuse the shaky camera work. I really need to get a camera man |
09-21-2007, 12:35 PM | #64 |
Pebble Pounder Join Date: Apr 2007 Location: Columbus
Very nice is that an actual hustler or your own build?
09-21-2007, 02:36 PM | #65 |
Quarry Creeper Join Date: Mar 2007 Location: 530
I'm pretty sure it's his own build. Lonewolf whats the last song in your 2end video? Your tuber is looking unstoppable! |
09-21-2007, 06:35 PM | #66 | |
The second song in the video is "Hang on" by Seether, and thanks for the compliments. | |
12-11-2007, 03:11 AM | #67 |
Pebble Pounder Join Date: Apr 2004 Location: Sydney, Australia
Very impressive little truck. I don't know how steep those climbs are but must be close to vert. Also amazed by how those tyres hook up. Nice work! Cheers, JK |
12-12-2007, 11:20 AM | #68 |
Thanks, I really like the maxx mashers, they grip pretty good on most of the rocks around here. I modded them recently into 2.2's and now am working on the perfect combination of foam and weight again. I had the old combo pretty dialed, but wanted a bit more sidewall and better looks. I cut the old tires off the rims and glued in some moab sidewalls, and then cut the centers out of a set of Axial beadlocks to get a better offset for the WK axles, plus I like the 14 mm hexes. The 12 mm hexes in the axials always round out on me. I epoxied the centers in place, and are holding up so far. I also made a pair of solid rear axles out of stainless. |
12-12-2007, 02:01 PM | #69 |
I pinched a few of your ideas for my latest rig. Love the integrated servo / upper link mount. Check out the battery mount I designed based on your axle mount idea: The rest of my buildup is here: MudCow's WK Trail Class Rig Again, nice work on the custom brackets etc. Very neat and compact. Much prefer this servo mount to the others getting around. BTW, the stainless solid axles are V.nice. Great idea. Might pinch that as well LOL... Cheers, JK |
12-16-2007, 07:46 PM | #70 |
Thanks MudCow, glad you like it. Feel free to pinch any ideas you want, that's what the board is for, the sharing of ideas. I don't know if the SS axle will be strong enough at the end where it goes into the diff. It might need some sort of heat treat to strengthen that part. BTW, I checked out your build and it looks sweet. I really like the sheet metal tuber idea. Looks pretty simple and tough.
