| | #1 |
| Rock Stacker Join Date: Feb 2007 Location: Whitecourt
| I've been working on this for a while now, finally getting it close to done. Still need to work on the suspension geometry a bit, and make the body panels. It has a 14" WB, I might shorten it up to 13" as it hangs up pretty easy. Also lower the bottom links to the bottom of the chassis. I am running a 3 cell 2100 lipo, and an AXI 2808 outrunner, it has lots of power, enough to snap axles. It does heat up the Mamba 25 tho. Since nobody has axle shafts in stock, I dug through my junk box and found some old Tmax CVd's. They are the right diameter, but there isn't enough room in the stock hub for the bigger bearings. So, I took some spare Tmax hubs, cut them down and made some adapter plates, and presto, HD CVD's for my WK axles. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jan 2007 Location: Midway
| Looking good!!! I like the mods!!!! Way to get it done!!! |
| | #3 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| Check out the big brain on Brad!! |
| | #4 |
| I wanna be Dave Join Date: Jan 2006 Location: CA
| Awesome job on the Maxx knuckle swap with CVDs!!! Also like your lower axle link mounts, got any more pics of those? |
| | #5 |
| RCC Addict Join Date: Mar 2006 Location: Xxx
| What is the track with onit ?:? |
| | #6 |
| Axial Team Driver ![]() Join Date: Feb 2005 Location: OC
| Wow looks great! Nice work on the cvd's |
| | #7 |
| Newbie Join Date: Jul 2006 Location: On the Rocks
| Cutting edge man, very nice. You got a build thread? |
| | #8 |
| Quarry Creeper Join Date: Mar 2007 Location: Syracuse
| That looks stellar. Great work! |
| | #9 |
| Newbie Join Date: Mar 2007 Location: Gainesville
| Very nice! |
| | #10 |
| Hey, thanks for the compliments. The track width is 10.75 inches, with the narrowed maxx mashers. I also have some 2.2 moabs, but they look really tiny on those axles. I was thinking about cutting out the sidewalls from the 2.2's and gluing them on the maxx mashers, but now I have the maxx hubs, so I don't think it will work. I am working on some pics of the axle mounts, and the servo mount right now, just have to upload them. |
| | #11 |
| Here are some pics of the aluminum lower link mounts. They clamp the axle pretty tight, and hang down less than the stock mounts turned sideways. Pics of servo mount. I might add in a brace from the front of the servo to the axle just to make sure nothing moves. Pic of tranny plate. All were made from 1/4, 1/8 and 1/16 inch aluminum, drill press, hack saw, files and a homemade belt sander. As you can see, I have been doing some testing, and it is a little muddy right now. Also, please ignore the wiring mess, I only temporarily mounted everything for testing, I will be making a lexan shelf for the electronics, and hiding most of the wires. |
| | #12 |
| RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
| | #13 |
| Thanks, it just takes a little elbow grease, and yes, they are traxxas big bores. I just need to find the right internal springs now. |
| | #14 |
| Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
| nice work man |
| | #15 |
| Newbie Join Date: Feb 2007 Location: CA
| Looks great, that should hold up pretty good. |
| | #16 |
| | #17 |
| If you look close, you will see that I had to angle the inside of the mount to fit over the ridge on the axle. The taper also holds it in place against the ears on the axle. |
| | #18 |
| Wishing I was Crawling ![]() Join Date: Feb 2007 Location: Missouri Boot-Heel
| talk about some serious inginuity, highly impressive. great job, looks real good. |
| | #19 | |
Again, very nice work!!! | |
| | #20 |
| Got a few more things done today, relocated the lower links and shortened the wheelbase to 13 3/8". With the relocated links, I had to file grooves in my skid plate for clearance, but now there is less of a chance of hanging up on the skid plate. The rear links should be very close to 100% anti-squat now. It's amazing how any little change can screw up your anti-squat. I also brazed on some body panel mounts. |
| Thread Tools | |
| Display Modes | |
