Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: And so it begins... sneak peek
Old 02-20-2014, 05:05 PM   #261
Default Re: And so it begins... sneak peek
Hmmm, I do know a man who could do that... There's a pic of him a few pages back lol
simon170 is offline   Reply With Quote
Old 04-03-2014, 04:37 PM   #262
Small update. Kimbrough servo savers are on and joining bar made, tested them out, they work fine in tandem and don't fight each other.
New wheels have arrived home safely courtesy of a friends visiting your great nation.
Kyosho offset rod ends and balls have arrived, for steering links.
Pulled axles and measured. This proved tricky as Kyosho didn't make their axle housings true/square, one end of the tube is 20.05 and the other is 20.68 and just about nothing is the same from one piece to the next.
Billet round stock has arrived for axle mods.
More to come...
Old 04-10-2014, 06:21 PM   #263
Axle wideners made and installed.
Wider front steering link installed with new offset rid ends.
New rear lockout done.
Servo mount finished
New wheels with tires mounted and on truck.
Suspension geometry rejigged front and rear.
Cut up axle shafts and fabricated extenstions, being welded together this weekend.
Sorry no pics, but just cramming to get it finished. Should have a test run this weekend.
If I ever see a lathe again it will be too soon...
Old 04-10-2014, 07:46 PM   #264
Bart bender's Avatar
I'm sure it's top shelf Simon. Can't wait to see it.
Bart bender is offline   Reply With Quote
Old 04-11-2014, 05:48 AM   #265
Thanks mate. Hope it comes together. The axles should be über strong now, even though they are wider. Will gets some pics up at the weekend.
Fingers crossed for the welding to go ok, got to weld bright steel to hardened steel so it's a bit tricky.
Old 04-18-2014, 01:32 PM   #266
Welding went well, so driveshafts are extended and have held up to a few test runs.
The steering still sucked, both the servo savers had to come off as even the Kimbroughs aren't strong enough. So gone to solid horns. Had to clearance the axle carriers to get more steering angle, which has made the wheels hit of the offset rod ends at full lock, so now had to make a new front drag link that has a offset in the middle to clear the diff and keep steering angle.
Old 05-07-2014, 11:15 AM   #267
Hi guys, sorry the latest updates are taking a while, I'm at the debugging stage with the truck but I've been having some health problems again which have slowed things down.
But have made some good progress so I'll get you caught up...
New wheels... lighter and less offset to help with steering. So far they are a winner, very happy with them.
Yet more lathe work, made a set of four axle wideners (mentioned earlier) these make the axles about 30mm wider each side, so the axles are about 15" hex to hex.
The piece goes from the diff housing all the way to the end of the hub carrier, so makes the axle super strong. These took freakin hours to make, as they are an exact interference fit.
3mm alloy wall thickness plus the original axle housing
"Disco" Dave welding up the extended axles I fab'ed up. I can stick or MIG, but cant TIG.
New steering setup finished...
These had to have a nibble taken out of them, but other than that all fairly straight forward.
I just love reminding myself and damn big this thing is
Well, it only took 2 years, but she finally made it out to the local crawler meet. The guys seemed to like and seemed interested in it, which was kinda nice. Did feel good to finally use it in anger
Fitted the 6lb springs to the shocks, as she was a bit wobbly lol (yes its a she haha)
She digs holes in the ground that verge on terraforming...
Well, there she be, new friends an all.... Ladies and Gentleman I present to you, "Artemis: Goddess of the hunt, the hills and the forests"
Comments, criticism and abuse welcome
Old 05-07-2014, 06:07 PM   #268
WOW........................
Thats just sick as hell
Regards Rick
v84x4 is offline   Reply With Quote
Old 05-07-2014, 06:49 PM   #269
Gold Star Baby!
vwmopar's Avatar
That's bad ass. I need to get mine up and going again. Are two steering servos necessary? I'm only running one with jumbo kongs.
vwmopar is offline   Reply With Quote
Old 05-07-2014, 07:12 PM   #270
~THE SCALE SHOP~
wow! what a journey! so good to see this chassis finally out there on the trails!
epic project!
STANG KILLA SS is offline   Reply With Quote
Old 05-07-2014, 09:20 PM   #271
Excellent. Glad you got that worked out. I bet the steering is 10x better now.
Might as well make a video for us to see.
67mustang is offline   Reply With Quote
Old 05-08-2014, 06:32 AM   #272
Which one is it?
Old 05-09-2014, 08:21 PM   #273
Wow, man really cool work on this build.
That thing is a monster!
Hacksaw707 is offline   Reply With Quote
Old 05-12-2014, 09:36 AM   #274
Regards Rick
Thanks Rick, wouldn't have been possible without your parts
Oh definitely, I tried one and it wouldn't cut it, then tried a 1/4 scale, no dice. The dual 7980's with the revised wheels is the only things that cuts the mustard. I think it she shear weight of this sucker that makes it so difficult.
epic project!
Thanks man, your chassis is the heart of the monster
Yep, sooooo much better now, its nice to have a truck that actually turns lol
Video is coming
Originally Posted by Bart bender View Post
Which one is it?
The little one on the end
Thanks man
Old 05-12-2014, 12:25 PM   #275
SuperShafty.com
excellent work in the end friend. nice to see it out with some of the other trucks too.
really bery nice job from the start to the end.
mjderstine is offline   Reply With Quote
Old 05-12-2014, 05:32 PM   #276
So how long till you cut your tires?
Old 05-13-2014, 05:01 AM   #277
Why would I do that mate? Think I should?
Old 05-14-2014, 07:13 PM   #278
You think they dig now? Cut the small lugs out
Old 05-14-2014, 07:17 PM   #279
Old 01-23-2016, 05:35 PM   #280
I'm back!
Anyone still around?
And so it begins... sneak peek - Similar Threads
sneak peek Mr Glassman General Crawlers 43 05-26-2006 04:38 PM
