Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: Axial internals in WK axles?
Old 03-23-2010, 05:25 PM   #1
Default Axial internals in WK axles?
Do the Axial axle gears work in the WK axles? I have WK axles on my Willys and later realised I couldn't use the MIP drive shafts because they don't fit the out shaft on the axle. So I had to go with plastic ones. They seem to be holding fine but when I go up something steep I hear some noise. Not sure if the drive shaft is slipping inside or if it's my axle. The thing is I bought the axles from a friend who previously locked them with JB Weld. So if it is the axle, it's only gonna be a matter of time before they strip in which I'd like to switch the gears to Axial so I can also use the drive shafts. Did I confuse you guys?
Linx is offline   Reply With Quote
Old 03-23-2010, 05:49 PM   #2
PapaGriz Yo
Grizzly4x4's Avatar
In my Slash/Trophy Truck WK rear axle I installed the Axial high speed gear set and the Axial locker. The WK diff housing bolted right to the Axial ring gear.
The ring gear, pinion gear, and locker were a perfect fit.
Grizzly4x4 is offline   Reply With Quote
Old 03-23-2010, 06:56 PM   #3
Same here, stripped out my dif gear and only had some spair axial internals, and they fit perfect
smm_cbf is offline   Reply With Quote
Old 03-24-2010, 02:41 PM   #4
Was that out of a stock AX10/SCX10 axle?
