09-28-2010, 07:57 AM | #21 | |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Ha ha I don't know if that will happen I don't know if I have a box big enough to ship it now ha ha I almost have all the windows cut out (sence they where all blacked out). And I just ordered 2 window nets from team3six. I'm hopefully going over to muddauber's this weekend and we may be able to do a little something to this thing. Thanks for looking Adam | |
09-28-2010, 09:00 AM | #22 |
09-28-2010, 10:40 AM | #23 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
Ok, thanks for checking. guess i'll start checking the side of the street |
09-28-2010, 11:29 AM | #24 |
Ha ha that's where u find all the good stuff though is at garage sales and stuff
09-28-2010, 01:01 PM | #25 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
| This looks like it will be a lot of fun
great body should be a lot of fun to build. I have a build that is on hold untill snow falls. you should take a look. Has some work that might help u with your build. It's in the large scale under Big block tj. I shure wish that someone built scale dana 60 axles in 1/8 scale. these big scale are a lot of fun to build and easer to build in a lot of ways. but parts are hard to find.. I show how to jump some of these hoops that you will face.
09-28-2010, 01:03 PM | #26 | |
Yah I know what ur saying I think I am going to go for a scale terraflex axle. Do u have a link for ur build I'd like to see I need all the help I can get | |
09-28-2010, 01:21 PM | #27 |
~ Got PROPANE ? ~ Join Date: Feb 2009 Location: East-Central
After looking at my pics...up above...I've got a correction to make. Those axles shown...were Axial Axles....with the Nylint Adapters on them. I took those pics for a guy that I deal with in Australia....and he bought those adapters from me...for one of his projects. I currently...have the same adapters...mounted up on brand new Wheely King Axles...and that is what I'm planning on using for my 1/6th Scale...Jeep Gladiator build. (If I ever get the time to get started on it !!) Anyways....I just didn't want any confusion....about what was actually being shown. Thanks AROn |
09-28-2010, 01:24 PM | #28 |
Yah I didn't think those where wk's Where do u get thoes adapters I think they will work for my hummer |
09-28-2010, 01:33 PM | #29 | |
RC4WD makes them. I'm not sure but these look very similar to mine. I don't have much CLOD...or TXT experience...so...if clod/txt's have 12mm hexes...these adapters should work for you Good luck buddy ARON Last edited by BiG_DaWgZ; 09-28-2010 at 01:35 PM. | |
09-29-2010, 08:34 AM | #30 | |
I think they will work I'm putting them on my wk axles. I was thinking for the bronco running a devorced drive train. Will a transfer case hold up to the abuse one of theses monsters Will put it through. | |
10-01-2010, 02:44 PM | #31 |
| I'll rty |
10-01-2010, 02:55 PM | #32 |
| I haven't got the frame built
I do have a template made of cardboard. here is what I have planed so far. I thought that a jeep hood would make a good hood scoop! also added a dog the the passenger seat for a dded touch. the bumper will be a lot like the one I'm building for my jeep gladiator. Ill show pics of it as well. I built it to be different and so u will see that it has a bobed bed. it is large scale as well. I find that these are much more fun to build and that the winches and other parts are more scale on these builds. |
10-01-2010, 03:07 PM | #33 |
| Good use of a bumper
The bumper i'm using is also the servo mount for the steering. |
10-01-2010, 03:13 PM | #34 |
| I don't know how much your into
Chopping bodies or if it is something that your thinking about but looking at the bronco that you have. I think i would give it a shot. On the back end is a good start. The end corners. I like this body. I think I will look for one and try it. good luck with your build and Ill be watching.
10-01-2010, 03:38 PM | #35 |
That looks awsome man I can only hope mine turns out half as good. What is the track width in that
10-01-2010, 03:59 PM | #36 |
Which one the black one or the green one?
10-01-2010, 04:00 PM | #37 | |
Thanks a lot I am going to remove the bumpers and make new ones. And I am back and fourth on taking the back off of it. Any one have any input | |
10-01-2010, 04:02 PM | #38 |
10-01-2010, 04:21 PM | #39 |
10-01-2010, 05:09 PM | #40 |
| Their 2.2
HPI rims. also here is a photo of a bronco that was cut up that some thought was foolish due to how rare the body was. |
