06-18-2012, 05:24 PM | #1 |
Rock Crawler Join Date: Jul 2010 Location: youngstown , Hillbilly heaven
| Hillbilly Willy's
GOING TO BE DOING SOME SCALE BUILDS WITH VENOM/ATOMIK CREEPER KITS TO SHOW WHAT CAN BE DONE WITH THEM. FIRST UP IS A 1/6 21ST CENTURY WILLYS JEEP. PARTS LIST: VENOM/ATOMIK CREEPER KIT GCM CROSS CANYON CHASSIS ATOMIK SLASH REAR SHOCKS JUNFAC WHEEL WIDENERS MORE TO COME.......... CUT THE SCALE ENGINE TO FIT OVER THE FORWORD MOUNTED TRANS. MORE PICS TO COME. Last edited by HillbillyCrawler; 10-21-2012 at 02:13 PM. |
06-19-2012, 01:14 PM | #2 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
| re: Hillbilly Willy's
Venom Creeper Axles??? How 'bout some undercarriage shots? Nice job using the 21st flathead, that looks great. The seatcovers are a nice touch as well, they came with the Jeep or did you make them? Last edited by Big Mike; 06-19-2012 at 01:17 PM. |
06-20-2012, 12:41 PM | #3 |
| re: Hillbilly Willy's |
06-20-2012, 12:46 PM | #4 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
i would like to sugest that u should take the side plates off and shave mounting nubs for them off. also i would sugest getting the Hot Racing rear locks outs, aluminum chubs, and aluminum knuckles. rigs looking really good so far thou |
06-20-2012, 01:53 PM | #5 |
Damn, those axles aren't bad looking at all! They appear to have a little slide mechanism to lock/unlock the differential?? Or is it just a little plate, flip it one way to lock the other way to unlock? That would be a cool feature to remotely operate if possible... |
06-20-2012, 04:35 PM | #6 |
The front diff will have the remote locker kit in it. You can do both but I only have a three channel radio. You are right about the axles. They are pretty cool. I wish the dig unit would fit. Will get the rear lock outs thanks for the heads up. |
06-20-2012, 07:27 PM | #7 |
Quarry Creeper Join Date: Jun 2009 Location: Visalia, CA
I am in the middle of building a Willys on the same frame (GCM) on wraith axles. I am having a lot of trouble with everything (suspension links, panhard bar, ride height) working together. Yours seemed to go together nicely. I may have started with the wrong body, the flat bottomed GI Joe, had to resort to cutting out the floor to drop the body over the frame. Yours looks great so farMore pics please!
06-20-2012, 08:21 PM | #8 |
Shoot me some pics. Would be glad to help you with yours.
06-23-2012, 12:47 PM | #9 |
Newbie Join Date: Jun 2012 Location: Greece
Hi. I'm building a 1/6 crawler also using the Venom Creeper axles (so that I can have the locking differentials ). Could you give me the total width of the axles with and without the wheels (including the wideners)? I'm aiming for up to 33cm or 13 inches of width with the wheels, will that be possible? By the way, nice and innovative build, you are one of the first (or maybe the first) to use the Venom Creeper axles for 1/6 scale in the forum. Oh, and why don't use the third channel to control both differentials using a simple servo Y? |
06-24-2012, 07:36 PM | #10 |
My axles are 11" from outside of the tire to outside the tire. That's with the 2 19mm wheel wideners. You could get the width you are looking for if you use Mayhem wheels like I'm going to do. Just get the large hubs. Hope this helps. What body are you using?
06-24-2012, 11:29 PM | #11 |
Thanks. I've got the build planned, now I need to buy all the parts... I'm using a 1/6 New Bright Jeep Rubicon body. I've kind of changed my mind and think I should rather use the 1/8 New Bright Jeep JK body which will still fit my project and the Venom Creeper axles better, and it actually looks much more scale. (The drawback is I will need to get one.) And for the 1/6 New Bright, I anyway have a chassis almost ready, it's based on a Traxxas RC. Whenever I finish that I'll make a post with pics. One more question: Center of gravity. I wanted to know if the "heavy" wheelie jeep body makes your rig roll over lets say 50° side hilling or 60° climbing. The New Bright bodies are also heavy. |
06-25-2012, 07:37 AM | #12 |
The climb will be fine. Side hill might be harder. Just remember that they are more of a scale trail rig than a scale comp rig. |
06-25-2012, 09:06 AM | #13 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
The rig looks good... The selectable diffs arent going to last long...the lock ring is aluminum with steel press fit pins and the diff carrier is plastic...the pins clown out the diff carriers pretty fast...there are upgrade diff carriers for the Venom axles but most Venom drivers lock the axles...I make Lincoln Lockers for the Creeper axle that never fail... |
06-26-2012, 10:41 AM | #14 |
Thanks for all of your help Thomas.
10-21-2012, 01:57 PM | #15 |
Got my new Pitbull Rock Beasts II in last week and had to see what they will look like on the willys . Mayhem trailready wheels are on the way. Sorry about the pics. |
10-21-2012, 02:49 PM | #16 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
So where is the motor? Are you gonna have it stick through the firewall?
10-21-2012, 03:23 PM | #17 |
| Re: Venom/atomik/gcm/hillbilly crawler 1/6 g.i. Joe willy jeep
Motor will be in the firewall just barely. I hope to test run it in about a week. Waiting on shocks. |
10-21-2012, 03:33 PM | #18 |
| Re: Hillbilly Willy's
Cut out the shifter and drilled it to take the shaft of a micro toggle switch. On/off Will do on for the lights also. |
10-21-2012, 04:05 PM | #19 |
RCC Addict Join Date: Aug 2007 Location: Burbank
I think the shock ran away That thing looks really good, I like how you kept the motor it it. Too bad its not high enough for the mud down there. You better sent it up north where it will get better use.
10-22-2012, 07:31 AM | #20 |
I don't build mud trucks Mike I can't stand mud. Just tears stuff up. Full size and rc. Darin thank you for the new iner renders. A lot more steering now. Even with the big Pit Bulls. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/large-scale-rigs/389205-hillbilly-willys.html | ||||
משהו חמוד | This thread | Refback | 02-25-2013 03:02 AM | |
משהו חמוד | This thread | Refback | 02-25-2013 03:01 AM |
Hillbilly Willy's - Similar Threads | ||||
HillBilly Hell | jeepinkid83 | 1.9 Scale Rigs | 21 | 11-02-2013 07:56 PM |
SCX10 Bronco Now With More HillBilly | HotCarl73 | Scale Videos! | 2 | 12-09-2011 07:18 PM |
The Kung fu Hillbilly | slobin3d | Chit Chat | 20 | 05-27-2010 01:18 PM |
HillBilly HellRazor | hbj069 | Team Losi Comp Crawler | 24 | 07-08-2009 09:48 AM |
The Huntin' Hillbilly | BJoe | Chit Chat | 0 | 10-03-2008 08:49 PM |
