07-19-2012, 01:27 PM | #21 |
Quarry Creeper Join Date: Jun 2009 Location: Visalia, CA
| Re: NorZepol's Willys |
07-19-2012, 07:28 PM | #22 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| Re: NorZepol's Willys I like how you are paying attention to all the little details. This Willys is coming together very well. Good job buddy. |
07-19-2012, 08:10 PM | #23 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
Nice job, can't wait to see it finished! |
07-28-2012, 11:34 PM | #24 |
Got some more finished. Man this is slow going. A shot of the tranny tunnel, functioning console and a little detail added aroun the edges. |
08-12-2012, 01:22 AM | #25 |
Got the body painted. Still needs the dull coat. Not perfect but good enough for me. Seat mounts installed w/ shoe goo. Front axial bumper with winch also. Should be able to mount the seats and the cowl to body, body to frame tomorrow. Waiting on an LED harness from Chaotic Crawlers, that and other electronics install next on the list. Then hopefully DMG can build me a cage. Last edited by NorZepol; 08-13-2012 at 08:33 PM. |
08-14-2012, 10:17 PM | #26 |
Some pics. |
08-25-2012, 12:39 PM | #27 |
Got the lights wired up. Installed the original "canvas" top, dyed the green to black first though. Was gonna install some hood pins, but when I monted the body the hood seemed to click into place and hold pretty good. The last pic is the bracket I built outta some aluminium angle. It mounts to the top 2 tranny case bolts and is where I mounted my electronics. Also built a battery mount in front of this bracket (no pic yet) but my battery was a bit too big. Ill post a pic when I get it situated. |
08-25-2012, 12:55 PM | #28 |
Rock Crawler Join Date: Jul 2010 Location: youngstown , Hillbilly heaven
That's looking pretty damn good.
09-03-2012, 09:56 PM | #29 |
Just about finished up until DMG can build me a cage. Here are the brackets I made from angle aluminum to tie the rear of the body to the frame. Added some brake rotors Holes for tail light made with just a drill and a file, not fun or easy. A couple shots of the lights, spare, jack and gas can. Last edited by NorZepol; 09-03-2012 at 09:58 PM. |
09-03-2012, 11:00 PM | #30 |
Here is a battery mount I made from aluminum strap and angle, still needs some slots for a strap, also a shot of the electronics mounted up. Some interior shots, gauges, and the shroud I built to house the extra led available int he harness First drive around the backyard Still need to install dash plaques, measure and order all needed suspension links, get another shackle for the front bumper, and upgrade most of the plastic on the axles. Thats all for now but you all these damn things are never finished |
09-07-2012, 09:02 PM | #31 |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
Looking good the ar60's look great under these rigs can't wait to see how you finish it off
09-07-2012, 10:53 PM | #32 |
Quick question what hub width are you using with those wheels the. 450 or. 650 ??
09-07-2012, 10:59 PM | #33 |
09-08-2012, 12:26 AM | #34 |
Doh one more question what is the width of of the nose from fender edge to fender edge. Just wondering if it is the same as the hasboro Willy's |
09-08-2012, 12:36 AM | #35 |
09-09-2012, 09:50 AM | #36 |
Thanks for the measurement and it is wider than the hasboro jeep :(. I was going to order a set of those wheels for build but they look wide on the ar60 even with the narrow hubs on ...... hmmm do you know or could you take a measurement from the rear axle and measure from the center to center of the tires so I can compare it to my set up if you don't mind that is . I am running rok loks on mine and I am wondering if the slightly smaller tsl is giving the optical illusion of a wider stance |
09-09-2012, 01:41 PM | #37 |
Quarry Creeper Join Date: Jul 2011 Location: olympia
i plan on using some tiny neodymium magnets i got from harbor frieght to hold the hood down... just thought id throw that idea out there in case you have issues with the hood popping open it came out looking great... id lose the extra tire but i guess that a personal preference |
09-11-2012, 10:14 PM | #38 | |
| Re: NorZepol's Willys Quote:
09-11-2012, 10:17 PM | #39 | |
09-12-2012, 11:55 PM | #40 |
i found them in the front... by the cash register... package says 10 pc. rare earth magnets item 67488... they are 5/16" by 5/64" thick...
NorZepol's Willys - Similar Threads | ||||
NorZepol's Jeep | NorZepol | Losi Micro-Rock Crawler | 2 | 12-16-2011 04:33 AM |
NorZepol's Bwroncho | NorZepol | Axial SCX-10 | 6 | 12-14-2011 12:29 AM |
Norzepol's Wreckluse 1.9 UPDATE | NorZepol | 1.9 Scale Rigs | 14 | 06-19-2011 09:52 AM |
Norzepol's Wreckluse 2.2 VERSION | NorZepol | 2.2 Scale Rigs | 9 | 03-01-2011 08:50 AM |
