01-04-2016, 06:55 PM | #41 | |
Newbie Join Date: Oct 2015 Location: CA
| Re: Buck's 1/6th all metal Willys Jeep Quote:
I did it mostly for strength, but also for better brakes (easier to service too), as well as to make it more capable (lockers) and to change the ratio. The original 5.38 ratio was way to much, even for larger tires. I have a turbo diesel in there for the motor, and the overdrive unit apparently didn't like the torque, so I took out the T90 3 speed and overdrive, and put in a T98 4 speed with no overdrive on the back of the transfer case. I broke the passenger side rear axle shaft of the D41.... on the street. haha! | |
01-04-2016, 09:10 PM | #42 |
What kind of diesel, how many cylinders?. I don't know a whole lot about diesels, but I was just watching a show on Discovery channel with a bunch of guys that hop up diesels, and they were building a'48 or so Willy's pick up, and they put a 4cyl Cummins into it |
01-04-2016, 09:16 PM | #43 | |
The fit was real good, it weights almost identical to what the original flathead did, and is about the same size (straight 4cyl) And a guy in Canada (Overland Diesel) makes adapter plates for these motors. I'd love to put a 4cyl Cummins in my TJ, but California would not let me register it with a diesel motor when it was original gasoline | |
01-05-2016, 06:26 PM | #44 |
But even with the Kubota motor, won't you have the same issue with registration?
01-05-2016, 08:43 PM | #45 |
Nah, in California anything older than 1974 (or whatever year it is, somewhere around there) is exempt from smog inspection, so you can do whatever you want. But the TJ still needs to be smogged.
01-06-2016, 10:52 AM | #46 |
Quarry Creeper Join Date: Nov 2013 Location: California
I don't think you can put a truck engine in a TJ either. My friend fell into this California BS trap. Nice 9" though. |
07-27-2016, 04:08 PM | #47 |
The big jeep is doing good! The axles work great, and the larger tires are nice. (33") Having trouble with my compressor though, so no locker action yet. Took it to Moab earlier this year, and then all the way cross the US and back, nearly 6,000 miles in an old jeep, and no problems. Time to focus a bit more on the RC jeep. So, I could try and re-use the coilovers from the original Exceed kit, but they have plastic ends, and I'd really like to have everything be metal. Are there any aftermarket suspension that would work decently for the weight of the metal body and axles? Right now the weight is over 13lbs without the battery, interior, and armor. I'm going to mount them from the top of the axle tubes, up through the body onto the cage with hoops. So the height isn't really super critical, I can mount them however. Ideally I'd be able to find a coilover that is thin, almost real-world 1:6 scale, like a tall FOX coilover or something. Any suggestions for the coilovers? I'll measure how long they need to be at ride height. I don't need a whole lot of up travel though, so I may not actually need a very long shock. Save Save Last edited by danielbuck; 07-27-2016 at 04:22 PM. |
07-27-2016, 05:54 PM | #48 |
I had a set of T-maxx shocks on mine, with the gray Axial springs, but they leaked all the time, even after I rebuilt them. Switched to 4 102mm Proline PowerStrokes, much better, even reduced the torque twist I was getting
07-28-2016, 10:00 AM | #49 |
ordered some 110mm shocks and springs from RC4WD, I'll start messing with mounting them when they arrive |
07-29-2016, 07:35 PM | #50 |
nice video clip! The small oil burner doesn't sounds all that different from the original flat head in the exhaust note. Can you post a pic of the motor?
08-01-2016, 10:37 AM | #51 |
got the shocks mounted, and the steering arms. I need to do a bit of cutting here and there, but it's sitting on it's own weight now. I'm using the stiffest springs all around, blue markings on them I believe. Need to order some motors for the axles next. Any suggestions? Last edited by danielbuck; 08-01-2016 at 11:18 AM. |
08-01-2016, 11:08 AM | #52 | |
Yea it sounds like a cross between a delivery truck and an old tractor. The camera didn't pickup the turbo sound very well, it whistles pretty good, I should call it the Whistling Willys. It drives great, I drove it across the US a few months ago, nearly 6,000 miles. zero problems. It actually sounds alot different than the old flathead, but the diesel just sounds so right in the jeep, it sounds like it belongs there. Almost everyone who asks me about it (who doesn't really know anything about old jeeps) assumes that the diesel is original, until they see the Japanese lettering on the manifold I love the motor. It's the same 2.2L displacement as the old flathead, and it only weighs about 20lbs more than the old motor. Plenty of torque, and the 3,000RPM limit isn't all that much of a hindrance even driving in varying speeds of traffic in LA. It's running 15lbs of boost, non inter-cooled. I'm hearing about some folks running 30lbs of boost, compound turbos, and other big setups on these motors without much trouble, so I'm sure I could probably dial up the boost later on, if the turbo is big enough to build more. I hear of some folks dropping in 4 cyl Cummins motors in these little jeeps, thats a lot of weight up front, I think those are probably double the weight! I like the Kubota. Last edited by danielbuck; 08-01-2016 at 11:21 AM. | |
08-01-2016, 07:14 PM | #53 |
Thanks! That is a tidy package, much cleaner than most of the V8 conversions that I've seen in person.
08-01-2016, 07:19 PM | #54 |
Nice work , Dan, on both the 1/6 and the 1:1 |
08-21-2016, 09:57 PM | #55 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
There are some nice Willy builds here. Your looks like it also will be a great build. Keep up the nice work.
10-23-2016, 02:18 AM | #56 |
I have a few free weekends coming up soon, I hope to get back and finish up the RC Willys. I need to cut the front of the frame to make room for the steering. Had a nice weekend in the TJ jeep, I need more weekends like this And we got my friend's 4 door jeep to have some fun too It's amazing how well the long 4 door jeep does out there, I think the longer wheel base really gives it an advantage in many spots. Me giggling in the background. |
10-27-2016, 01:34 PM | #57 |
Pebble Pounder Join Date: Feb 2009 Location: Augusta
Nice build(s) going on, man. While the 1:1 is mighty nice, I really like the 1:6. |
04-18-2020, 04:57 AM | #58 |
Quarry Creeper Join Date: Jan 2011 Location: Woody point
Old thread but what a great build, anyone know if it was ever finished?
04-18-2020, 09:47 AM | #59 | |
I don't know when it will be, but I'm definitely going to get back to this at some point. I picked up yet another full-sized project, a 33 chevy pickup, that'll be a slow burn too, haha | |
04-19-2020, 04:29 AM | #60 |
Life gets in the way! And I know how the 1:1 projects go, for myself I just have too many hobbies if that’s even a thing. No time for all of them. Would love to see you continue with it. Awesome you still have it considering that’s 4yrs ago |
Buck's 1/6th all metal Willys Jeep - Similar Threads | ||||
My 1:6th Willys Jeep build (GI Joe) | eunique | Large Scale Rigs | 102 | 12-02-2015 08:58 AM |
What happened to the cookie sheet 1/6th Jeep Willys | TheButcher6969 | General Crawlers | 0 | 03-12-2014 07:49 PM |
all metal 1/6th scale MB Willys | BigSki | Large Scale Rigs | 7 | 08-09-2012 09:35 PM |
