11-24-2009, 09:07 PM | #1 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Heat ??
So, I have only run the stock nimh battey for two charges. I put a 2 cell lipo in and notice quite a bit of heat after 6 minutes or so.The esc/rx combo is warm, battery cool but the motor is smokin hot, like hot enough to cause you to pull your finger away fairly quickly. I didnt temp it but I am guessing it was close to 140*. I have added a full wrap of 3/16 fishing lead rope inside the wheel and added a small 3/8 galv lock washer to the center hub. I know this will cause extra strain...... Anybody else notice warm temps ?? stock or modified ?? I wish I would have paid attention when it was unweighted for comparison. |
11-24-2009, 09:15 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
Yeah, we have noticed the heat, we had 4 going in the shop tonight and everyone of them, the motor got real hot. I'm running the 2S lipo and the ESC got a little warm, but not to bad, and another guy is running a lipo and his ESC also got a little warm.
11-24-2009, 09:17 PM | #3 | |
Newbie Join Date: Dec 2008 Location: paducah
11-24-2009, 09:20 PM | #4 |
Quarry Creeper Join Date: Oct 2008 Location: Spanaway, Wa
11-24-2009, 09:22 PM | #5 |
Pebble Pounder Join Date: May 2007 Location: Dirty Jerz
i been running the the Losi micro T lipo and my elctronics do get warm, but i swore i heard that these things are built to handle the 7.4
11-24-2009, 10:11 PM | #6 | |
| Quote: Speaking of which, I just put the stock battery back in and noticed that there was only a green light lit on the esc. When the lipo is in there is a green and yellow led lit. Is that indicating lipo cut off active or overheat or over voltage or ???? The light comes on as soon as the lipo is plugged in. | |
11-24-2009, 10:14 PM | #7 | ||
yep, for sure,may have to try that as I could actually smell the heat...thats what drew it to my attention. | ||
11-24-2009, 10:18 PM | #8 | |
11-24-2009, 10:24 PM | #9 |
Rock Crawler Join Date: Dec 2005 Location: houston
yes, it is compatible and is supposed to detect the lipo battery and change the low voltage cut off to account for it. 1/24 Losi Micro Crawler eye candy and tweaks |
11-24-2009, 10:59 PM | #10 | ||
11-24-2009, 11:01 PM | #11 | |
Newbie Join Date: Aug 2008 Location: Renton
11-24-2009, 11:04 PM | #12 |
how did she work with the BB2?
11-24-2009, 11:27 PM | #13 |
I have the first BB. Not the real ball bearinging'd BB II. I liked the wheel speed gain, but not the hot motor or shorter batt life.
11-25-2009, 08:21 AM | #14 |
11-26-2009, 03:13 PM | #15 |
Just temped everything Stock battery: esc was 87* motor was 97* after 8 min 2s lipo: esc 92*,motor 141* after 8 min Anybody now where to get a small heat sink?,I need to try something or this motor isnt going to last long. I may try gearing down, but I dont want to give up the extra wheel speed |
11-26-2009, 06:55 PM | #16 | |
11-26-2009, 07:21 PM | #17 | |
11-26-2009, 08:31 PM | #18 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Nahhh, that fits on the rear of the truck for Micro T's it wraps around the motor rather than on the motor. Give me a minute as I seen something that might help this issue. |
11-26-2009, 08:48 PM | #19 |
OK, its a $5.00 motor so if you wannna cook it then cook it. I guess the gearing issue is in the tranny that is causing the problem. according to one of my buddies, He replaced his motor with an RS4 micro high torque and the problem went away somewhat. The other thing he said you should try is perhaps change the pinion out to lower the temps, or goto a micro brushless set up for heli's as they are designed to handle more heat. My buddy is trying to rebuild the truck into a scaler and ran into your same issues.
11-26-2009, 09:01 PM | #20 |
