11-25-2009, 01:06 AM | #1 |
Pebble Pounder Join Date: May 2007 Location: Dirty Jerz
| binding in the tranny
Has or can any one else take off ther tranny, take out the motor and try to spin the tranny by turning the Spur gear. Mine was smooth but on portion. so i tore her all part, put her back togather and still the same thing. its driving me nuts?
11-25-2009, 01:39 AM | #2 |
Rock Stacker Join Date: Jan 2005 Location: Romulus
Yea mine has 1 spot that it kind of clicks likes it's catching on something But I haven't had time to pull it apart.
11-25-2009, 06:39 PM | #3 |
Rock Crawler Join Date: Dec 2005 Location: houston
Mine does the same. took it apart last night and found that the gears in the tranny are not perfectly round, causing binding. I found where it was binding and SLOWLY filed the gears to fit. File, test, file, test,.....etc. It's a lot better now, but still not quite perfect. Helped a bunch with low speed throttle control because now the motor doesnt have to fight the gears.
11-25-2009, 06:51 PM | #4 | |
11-25-2009, 07:00 PM | #5 |
Quarry Creeper Join Date: Jan 2008 Location: pittsburg
hey joey, fully charge your battery or two if you have em. and turn the thing upside down and let it run with no pressure on the drivetrain. mine did the same thing for a bit. but after 2 packs upside down the gears were broken in. like getbent said above its because the gears arent perfectly round. so you let them wear into each other and it will go away pretty quick
11-26-2009, 04:13 PM | #6 |
Rock Crawler Join Date: Jan 2007 Location: San Clemente, CA.
Mine is the same way, but they are taking their sweet time breaking in. I wait a little longer before I tear into it, as I know once I take it apart I will end up building a new chassis etc......
11-26-2009, 08:03 PM | #7 | |
Newbie Join Date: Mar 2008 Location: Liberty
1. The output gear is warped (on mine). It does not run true on the output shaft...it wobbles side to side. I tried to clean and re-seat the gear on the shaft but the gear is simply warped. There is no debris or anything on neither the shaft or the gear where they mate in the "square". That being said. I don't thing that's where the binding is. 2. The binding occurs at one specific spot per revolution of the output shaft. This indicates there is an issue with the output gear teeth. Problem is it's so small I can't see where to clean, file or tweak (I will have to wait until daytime as my work area lighting isn't cutting it). I do have a magnifying glass but the lighting is reaking havoc on using properly. Can't say for sure but I think the output gear in the tranny is simply a bad part (again on my truck). Being both warped and potentially one or two deformed teeth or gaps. I will try to get some macro photos or a video...maybe we can digitally zoom and find the anomaly on the teeth. I love this truck but couldn't stand the sound (and knowing) of the binding. At some point it's bound to wear out or break prematurely because of this. That's what I got so far. I hope to update in a day or so. Maybe Rich from Losi reads these threads and could off some advice or direction? Thanks. | |
11-29-2009, 10:02 AM | #8 |
Rock Stacker Join Date: Sep 2004
SAME. (copy and paste of my post (funny how similar mine is to Hakinator's) from this thread: Anyone experiencing binding worm gears?) Just got into my transmission. 1. Spur/Pinion mesh was WAY off. The two sides of the slipper disk don't center the spur on the output. Messed with it for 10 minutes. I think it's a first run "problem?" Finally got it to about 90 percent by running the throttle with one hand and tightening the slipper with the other. Yeah, give it a try. BUT my binding wasn't gone. 2. Pulled the tranny and found a pretty glaring problem. Tranny is DEFINITELY binding. From the factory. Turning the shafts by hand (finger) produces a grinding every rotation. When it's not grinding it's smooth as butta. Don't even have to "pinch" with my fingers to turn it. When it's bound it takes considerably more pressure to turn the shaft. I can't tell what it is. Output shaft doesn't look bent. Output shaft gear OOR? Spur gear OOR? Bad bearing? It's almost as if the seat for the bearing in the cover is MICRONS off. Goes away with the cover off. Comes back with cover on. EDIT: just flip-flopped the OS bearings: no change. Wondering if Rich is perusing this thread? I'm going to try to get video. The grinding is pretty audible. EDIT: VIDEO LINK: http://www.youtube.com/watch?v=-b3-KErVCyE ***HAS anyone PM'd Rich? Joeyblaze? I don't want to hammer him with the same pm he's gotten from 10 other people. I DO want to make sure he knows about this thread though. Last edited by shimey; 11-29-2009 at 10:07 AM. |
11-29-2009, 12:47 PM | #9 | |
Newbie Join Date: Nov 2009 Location: denver
see this is what happens when you make modifications , you get problems or maybe it really just is the gears Quote:
i had binding on mine but only for min, i came here and searched advice, this really does work and there is absolutely NO i repeat NO GREASE IN THE TRANNY AND AXLES Last edited by THX_138; 10-26-2016 at 11:39 PM. | |
11-29-2009, 01:13 PM | #10 |
Newbie Join Date: Nov 2009 Location: Lansing
| When I did the tranny flip, I found a light grease in my tranny, I don't know about my axles. I was disappointed to find that the tranny case is open by the motor. When I tear into it again, I'll see about sealing that with some monokote or a decal.
11-29-2009, 01:38 PM | #11 | |
I don't think this is an issue of run in or break in. I just ran my tranny through a full pack (losi 2s lipo from my micro dt) to "break in" the gears. Catches in the same spot and grinds just the same as before. | |
11-29-2009, 02:40 PM | #12 | |
11-29-2009, 08:18 PM | #13 |
^^^ Thanks for the tip. On your suggestion, I tried it, and several variations...but no joy. Still grinding/binding/stalling.
11-29-2009, 08:26 PM | #14 |
Pebble Pounder Join Date: Sep 2009 Location: Alabama
11-29-2009, 09:11 PM | #15 | |
I did some more "work" on mine and finally gave up and put my rig back together binding and all. I can't stand knowing it's binding but I also can't stand my new rig being disassembled on my bench. Another post on up or on another page mentions the gear isn't round. I got my digi calipers out and it showed a few hundreds of mm out of round. This couple with my gear not running "true"...IE warped...wobble I believe creates the binding. I don't want to take my rig back to get it replaced over this. I would much rather have Losi or Horizon replace the gear or even tranny. Also, on my rig the spur and slipper look fine and appear to run smooth and true. Does anyone know if any of these tranny parts are the same in any other losi micros? Could I buy something that is a direct replacement for a micro t that is essentially the same gear? I do not own any other micros so I don't know anything about their gear boxes. Thanks... Last edited by Hankinator; 11-29-2009 at 09:16 PM. Reason: Spelling | |
11-29-2009, 10:07 PM | #16 | ||||||
THANKS - Let us know if you hear from Rich. Peace - ck | ||||||
11-30-2009, 03:27 PM | #17 |
Hank and shimey i think your both dead on, as i feel mine are the same way. I just sprayed the crap out of them with Moo Slick and then re built. Hopping for a fix or hop up to get rid of this problem
11-30-2009, 06:36 PM | #18 |
12-01-2009, 07:47 PM | #19 |
Pebble Pounder Join Date: Feb 2009 Location: Long Island
I just got my micro today and it has the same binding issue. It sure makes being precise with the throttle tough when you're fighting the gearbox (especially with the lipo). Hopefully horizon will come out with a fix for this....and some new shocks with lighter springs...
12-02-2009, 09:15 AM | #20 |
Rock Stacker Join Date: Sep 2005 Location: davenport
Went a head and tried to figure this problem out on mine as well with no luck. I found the problem gear, marked where it's binding and took a hobby knife between the teeth to try and clean it.. Nothing. Even try sanding it down a little with some 2000.. nothing. Then I ran it with the battery hooked to the motor and the crawler upside down threw a pack and still nothing! Hopefully losi will acknowledge this because the low speed driveabilty would be really nice to have.
