12-01-2009, 11:21 PM | #1 |
Rock Stacker Join Date: Jun 2007 Location: Norway
| 2.4 Ghz Bind problems
Hello Got my Micro 2 days ago. I've noticed the following problem: It seems like the transmitter and receiver won't bind. When I turn on first transmitter then the receiver, no light is shown on receicer (no canal found). I try (have to) re-bind everytime I start. When I press the button on receiver the light blinks rapidly (as it should) when I seccondly turn on the transmitter the lightes go out (no match). After several attempts it finally binds. Suggestions? Last edited by KuJo; 12-01-2009 at 11:27 PM. |
12-02-2009, 05:16 AM | #2 |
Newbie Join Date: Apr 2008 Location: MN
I'm having a problem similar to this, everytime I charge I have to rebind. Altho mine does it instantly without problem.
12-02-2009, 09:34 AM | #3 |
Pebble Pounder Join Date: May 2007 Location: No Where
Ive noticed occasionaly when i turn mine on it has become unbound. BTW i have a RTR. It has taken up to a minute for the reciever to recognise the controller. Its a pain but thankfelly it only happens about 1 of every 10 times i power it on.
12-02-2009, 10:58 AM | #4 |
Rock Stacker Join Date: May 2004 Location: Spanish Fork, Utah
I have the same problem. I have found that I need to turn the truck on first, then the radio. If that doesnt work I just turn the radio off then back on and it always works. It is a pain but this is the only way I have found to get it to work. Re-binding would never fix it for me.
12-02-2009, 12:37 PM | #5 |
Rock Crawler Join Date: Jan 2007 Location: Tuscaloosa
I'm having the same problem guys. I had been meaning to start a thread and never did. I'm glad someone brough it up so I know its not just me.
12-02-2009, 01:46 PM | #6 |
Quarry Creeper Join Date: Apr 2008 Location: Racine
You guys need to call up Horizon and tell them what's up. I'm guessing it's actually a problem with the transmitters. I have the BND and it was able to bind to the DX3S instantly and I've never had any trouble since then. |
12-02-2009, 02:10 PM | #7 |
Pebble Pounder Join Date: May 2007 Location: Dirty Jerz
mine takes about 20 seconds from the time i turn the controler on to the RC is responsive?
12-02-2009, 03:26 PM | #8 |
Pebble Pounder Join Date: Sep 2009 Location: Alabama
12-02-2009, 03:29 PM | #9 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
totally out of left feild here, BUT. Eflite's firtst run of their mico heli the MSR, the ESC's (5in1) on those are notorious for doing the same thing. they are a Horizon/Spektrum products as well. luckly Horizons CS is bombproof. Last edited by BEELZEBOB; 12-02-2009 at 03:39 PM. |
12-02-2009, 09:55 PM | #10 |
Rock Crawler Join Date: Dec 2005 Location: houston
Yep, mine is doing the same (RTR by the way), was just about to start a new thread but figured I would search first and found this. I have tried every combination and so far can't find a reliable way to get it to bind, gives me problems almost every time and is getting very annoying. If anyone finds an answer Id love to hear it.
12-05-2009, 10:11 PM | #11 |
Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
Mine is too! Do you usually have to send stuff back to horizon or how's that work?
12-05-2009, 10:57 PM | #12 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
I also have a DX3R and haven't had any problems. Must be with the radios.
12-05-2009, 11:41 PM | #13 |
Rock Stacker Join Date: Apr 2006 Location: Clovis
Also no problem with the DX3.0, about 2-3 second delay (at the most) when turning the truck on after the TX.
12-05-2009, 11:47 PM | #14 |
Quarry Creeper Join Date: Oct 2008 Location: Fresno
12-09-2009, 09:34 PM | #15 | |
12-09-2009, 11:00 PM | #16 |
THANKS !!!!!!!!!!!!!!!!!!! Changing battery in transmitter seem to solve the issue. I've tried it 5 - 6 times and it binds almost instantly. Hope it lasts. Changing battery is way to simple to be thought of - but should be the first to try on all battry-powered items. THANKS AGAIN !! |
12-10-2009, 01:20 AM | #17 | |
Gold Star Baby Momma! Join Date: Feb 2004 Location: Maumelle, Ar
I felt stupid when I finally replaced my batteries and it fixed the problem. I have only crawled 2 complete batteries with mine is the reason I never thought that the batteries in the transmitter could produce this issue. Kevin | |
12-10-2009, 06:22 PM | #18 |
Glad to know its working, seems the most obvious answers are the hardest to see. Guess the batteries in the kit are pretty junky. Oh well, at least its working now and I can play when I want.
12-18-2009, 07:50 PM | #19 |
Pebble Pounder Join Date: Feb 2009 Location: Oregon
Thanks for the info guys! Exactly the same problem for me. Only drove the Micro maybe 4 times and the radio batteries are junk...thanks Losi.
01-01-2010, 02:22 PM | #20 |
Newbie Join Date: Oct 2007 Location: Aurora
I had the same binding problem and the battery change worked for me as well. THANKS!! |
