01-02-2012, 09:53 AM | #101 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
| Re: The “What and Where To Buy” Thread
IIRC stock McRC spur is 54T
01-11-2012, 09:08 AM | #102 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
What alternative radio's and receivers can be used when you go brushless? everything I find is for airplanes with 4+ channels i just want a micro one for this set up. what options have people found?
02-02-2012, 09:45 PM | #103 |
RCC Addict Join Date: Jun 2007 Location: MESA
I forgot to add my addition here...for Predator motors please visit my vendor post here... http://www.rccrawler.com/forum/vendo...ro-motors.html |
04-07-2012, 04:40 AM | #104 |
Newbie Join Date: Sep 2008 Location: kansas city
ncp hobbies has 1/24th scale bodies in lexan and styrene http://http://www.ncphobbies.com/ and danally i got my ddt |
04-12-2012, 05:39 PM | #105 |
Quarry Creeper Join Date: Sep 2009 Location: Bay Area
Thought I'd add this servo to the list: HobbyKing R/C Hobby Store : Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo Metal geared, more torque than the HS-65MG. It's pretty tall compared to the stock and the HS-65MG, but I'm planning on not using the servo saver, which means I may be able to slide the servo up and get it to fit. I've ordered two and will update this post if I can get it to fit. |
04-25-2012, 09:51 AM | #106 | |
Newbie Join Date: Nov 2009 Location: Bergen County
| Re: The “What and Where To Buy” Thread Quote:
04-30-2012, 02:48 PM | #107 |
Pebble Pounder Join Date: Apr 2012 Location: Herndon
Anyone ever think about using the 1/25 Shocks/Struts? http://www.micronitro.net/struts__coilovers.htm He said he would get some measurements and get back to me. The sight says they can be cut to length so that would be good too. Right? Sent from my BlackBerry 9900 Last edited by olblueyez; 05-01-2012 at 11:36 AM. |
05-01-2012, 02:25 PM | #108 |
I also wanted to add that People choosing Servos for the Trekker, may have a little trouble getting some of the recommended units to work. On the Trekker you will have enough room for a Servo that is 23mm/.905". Those Hi-Tec units are .92 and forcing one in there will put a lot of pressure on the front axel housing(s). I used an HS-5065 and I had to grind the servo mounts down so they were closer to flat on the inside. I guess you could also use some 2mm washers/spacers to fill the gap between the mounts and the axel housing. People who want to use Aluminum servo mounts need to know about this. I have the Hot-Racing mounts with the battery plate (so I can add weight if I like, and I will be using the Nylon mounts I altered to make this work and not the nice anodized units that came with the HR kit. Sent from my BlackBerry 9900 using Tapatalk |
05-25-2012, 02:47 PM | #109 |
Newbie Join Date: May 2012 Location: East Coast
Everywhere I've looked the HR Transmission housing (not the cover) is out of stock. Does anyone know of a place that has it in stock? Thanks! MtN C. |
09-16-2012, 11:58 PM | #110 |
Rock Stacker Join Date: Dec 2009 Location: Kansas City
so did anyone ever try those struts out?
09-17-2012, 10:10 PM | #111 |
RCC Addict Join Date: Aug 2012 Location: Philippines
Just Subbin, and a GREAT place to get custom build parts (IE tube, all thread, styrene) is 1. your LHS, and 2. hobbywarehouse.com
10-22-2012, 04:52 PM | #112 |
Newbie Join Date: Oct 2012
Hi, this is an awesome thread... does someone want to add the part number and a link to the lost Mini-t springs that everyone talks about using? I found them but im not sure weather to buy the front (LOSB1600) or back (LOSB1601) springs? or if there is even a difference in length or anything else. Thanks!
10-24-2012, 07:33 PM | #113 |
Rock Stacker Join Date: Jan 2012 Location: Dothan
I want my micro crawler to be a bit wider! Whats the best way?
10-24-2012, 08:35 PM | #114 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
Check the new threat with this info you have 3 options
10-24-2012, 10:48 PM | #115 | |
Danally wide offset mod is my favorite though, because it is free, and super deep dish wheels look awesome. Sent from my SGSII E4GT Last edited by gbean; 10-25-2012 at 09:21 AM. | |
10-25-2012, 04:32 AM | #116 |
Newbie Join Date: Sep 2008 Location: United Kingdom
The Danally method is good if you feel confident to carry it out yourself, as like gbean says, it's free & looks pretty good once done. The crawlingwide wheel wideners/weights look really good, but to fit them to a micro crawer you need to fit the stub axles from the micro trekker as they are longer (the kit is designed to fit the trekker only). |
10-29-2012, 05:50 PM | #117 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
I am posting this as a warning, HR (Hot Racing) and it's resellers (Hobby Etc.) have some awful website order forms, and in my case poor customer service. I also tried to order from Liquid RC, and the online order form was utterly unusable. I purchased 2 sets (8 total) of beadlock wheels from them (at approx. 40$ a set, 80$ total) and only received 1 set (4 total), the invoice said "2 items" and the website said one set (item) was 4 wheels (@ 40$). So I am short 4 wheels. I have emailed multiple times and have received no response of any kind. So it with some sadness that I post this, as the 4 wheels I did receive were good quality. If you can buy them at your LHS they are fine, but I would never order from their websites until they address this. *Update* The folks at Hobby Etc have gotten around to emailing me once, said they had sent a refund of the cost for the second set of wheels, I asked them what format was the refund (check, e-transfer etc.) and got no reply at all since. Also I haven't seen the refund yet either. I ordered one more set of these wheels from "The Toyz" and I am expecting better results from them. Last edited by KnutKase; 12-05-2012 at 06:53 AM. Reason: New Info |
10-29-2012, 06:44 PM | #118 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
are there any aftermarket pinions available? or do i need to get more losi originals, put my new DDT predator 90 in tonight and only got about half way down the hall before it spun the splines out of the pinion. should i have used a new one from the start?
11-24-2012, 07:50 AM | #119 |
Newbie Join Date: Sep 2010 Location: norway (europe)
size is 32x20x8 mm weight 10gr |
03-20-2013, 12:55 AM | #120 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
Just bumping the "lost" thread! Can this be restickied? |
