![]() | #61 |
Pebble Pounder ![]() Join Date: Jan 2010 Location: League City
By far the best looking micro scaler I have seen yet! ![]() |
![]() | #62 |
Rock Crawler Join Date: Feb 2009 Location: Milwaukee
![]() | #63 |
Rock Crawler ![]() Join Date: Dec 2010 Location: Madison Co.,Ms.
Killer build first off. You have this thing nailed, so I'm gonna pick your nugget about a few things....... If you don't mind? I intend to convert my Trekker, Miclaws and it's 130 can motor over to this chassis and build a 1st Gen Toyota Hilux out of it. 1. Have you found the wheelbase hampering? Wide turning radius? 2. How is the suspension working out? I occasionally come across comments about axlewrap with the leaf springs. A traction bar seems doable if so, the big ass tires won't do the leafs any favors. Should I order an extra set of leafs for breakage? They seem to be thin and a consumable part. 3. How is the travel and articulation with it? I expect it'd be way more stiff and limited compare to shock/link suspension. I'm not looking for mad flex with mine. Thanks for an inspiring build! |
![]() | #64 | |
| ![]() Quote:
2. For axle wrap... Leave on the bottom links. I haven't broken any leafs as of yet...(never hurts to have extra parts though) 3. Articulation is somewhat limited compared to (comp style) rigs... You will get plenty of flex for scaler rig, especially if your running mini-qlo's. ![]() ![]() | |
![]() | #65 |
Thanks T-buck! You've helped me decide on this chassis.
![]() | #66 |
Newbie Join Date: Dec 2011 Location: Slovenia
Can I use 1:24 plastic model for smc 5.5?
![]() | #67 |
![]() | #68 |
I'm ordered Lindberg body, so I have one little question! How long is this chassis (SMC 5.5) ? ![]() Last edited by Midlife Crisis; 12-13-2011 at 12:03 PM. |
![]() | #69 | |
I wanna be Dave ![]() Join Date: Feb 2007 Location: South FL
| ![]() Quote:
![]() the SMC 5.5 allows for a 5.5" - 6" wheelbase Blade SMC 5.5 EX [SMC5.5] - $44.97 : Crawler X, Rock Crawler Parts | |
![]() | #70 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
yeah, but spoo, he was asking about chassis length ... the WB will be shorter than the chassis. nikeridesbikes - if the WB is 5.5-6" factor about 2-3" additional length ... so, and I'm guessing based on the parts used ... the chassis will be around 7.5-9". That model will aslo have around 1/4-1/2" overhag of the chassis front and rear. I would guess it to be a good fit, but for the real answers PM Blade as he's the guy that makes these puppies. |
![]() | #71 |
![]() | #72 |
![]() | #73 |
Newbie Join Date: Jan 2006 Location: West Valley
Hey, I know this build has been around for awhile... Would you mind showing some pictures of how you attached the body?
