Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: big block question...
Old 02-04-2012, 02:49 AM   #1
Default big block question...
i have a 52t spur and im trying to use the 17t pinion and i cant seem to make them mesh up... i moved the mount up to where they are closer but i cant seem to get it it close enough... i tryed the 54t plastic one and it comes closer but they still dont mesh together... will the 56t mesh up with the 17t? or do i need to go bigger on the spur?...
brandonwalsh420 is offline   Reply With Quote
Old 02-04-2012, 04:24 AM   #2
Default Re: big block question...
have you tried using the small trans gear? It'll work.
Have you tried cutting some of the trans case away to allow the motor to get closer to the spur?
Rockfrog is offline   Reply With Quote
Old 02-04-2012, 10:10 PM   #3
i havent tryed cutting the trans to get it closer... i dont have any extra trans gears but its so retardedly close with the 54t gear i think it may work if i cut away part of the trans... im just curious if the 56t with the 17t spur will work without cutting the trans down?
Old 02-04-2012, 10:17 PM   #4
Midlife Crisis's Avatar
The bigger the spur, the easier mesh you can get without surgery to the case. Plus, there's not much to gain for the trouble of the mod. If your spur gets too big, you're gonna have to clearance the output shaft.
Midlife Crisis is offline   Reply With Quote
Old 02-05-2012, 12:26 AM   #5
i believe the 56t will fit without modding the output for clearance... but im no pro and please do correct me if im wrong
Old 02-05-2012, 12:41 AM   #6
59T is about the largest spur before any grinding of the output is needed. My how to uses a 59T rally spur and an unmodified output.
It's also the largest available without modding the gear itself (heli gears)
Old 02-10-2012, 06:10 AM   #7
What pinion (brand) are most people using for this. I read somewhere Robinson Racing Absolute Pinions fit right up. Im concerned about the pitch (gear mesh). No gear mod necessary would me the preferred method.
RCOG is offline   Reply With Quote
Old 02-10-2012, 08:18 AM   #8
I've been using Radical Racing brass pinions. They're a tight press fit, but they work. They come in 9, 10, 11, and 12T.
8695Beaters is offline   Reply With Quote
Old 02-14-2012, 08:20 AM   #9
Where can I find these at ?
Old 02-14-2012, 08:25 AM   #10
2nd smaller then a 14 mod 0.3 with a 2m' hole would be awsome!
thesnake505 is offline   Reply With Quote
Old 02-14-2012, 08:36 AM   #11
Originally Posted by thesnake505 View Post
2nd small then a 14 mod 0.3 with a 2m' hole would be awsome!
I feel like i should know what this means but i don't. I was looking to find out where i can find the radical racing pinions. I would still like to know what your response means. Thanks......
Old 02-14-2012, 08:49 AM   #12
Haha i see, well i meant
2nd what you said
And smaller then a 14t pinnion (the smallest iv found) with a 0.3 mod (pitch) and a 2mm center hole (cause a big block has a 2mm shaft)
Hehe hope this helps
Old 02-14-2012, 10:32 AM   #13
Got it
Cheers!!
Old 02-24-2012, 07:22 PM   #14
What is the pitch of the stock losi gears (non metric please)? Still looking for the best pinion option to use with the "big block"......
Old 03-07-2012, 11:44 AM   #15
Hey Guys, Im just wondering what currently is the best pinion option to use with the 130 motors?
Brand would be great, size, if anyone knows what pitch? Are there any options that bolt right up (no drilling&tapping needed)? Someone had mentioned somewhere RR Absolute pinions, if there is any confirmation on that?
Thanks
Old 03-07-2012, 05:26 PM   #16
Got it
Cheers!!
I have fit the 14T and I think 12T brass pinions used for the losi micro on the 2mm shaft of the 130 motor. just need a drill bit and round file smaller than 2mm to open it up clean it out.
just keep in mind a pinion that small wont contact the spur gear with the stock motor plate
spoo76 is offline   Reply With Quote
big block question... - Similar Threads
big block questions brandonwalsh420 Losi Micro-Rock Crawler 4 12-31-2011 07:11 PM
C/K packin big block heat livewires HPI Wheely King 10 05-09-2011 07:37 PM
Big block swap hitman46mod HPI Wheely King 12 12-15-2007 07:29 AM
