03-03-2012, 11:55 AM | #1 |
Newbie Join Date: Oct 2011 Location: Maine
| How to extend driveshafts
Im thinking about getting the blade smc 5.5 ex scaler chassis for my micro. But how do you extend the driveshafts? On a few really good looking scalers they have some silver tubing, where do you get that or what is it? Thanks! |
03-03-2012, 12:12 PM | #2 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
| Re: How to extend driveshafts
Grab your driveshafts and head to the LHS, find their tubing rack and start fitting the female end of the shaft in the tubing until you get a good fit.....buy toob! 7/32" or 9/32 is the rough tubing size. Next, aquire a small tubing cutter (Home Depot, etc. Smallest size). Assemble the rig with driveshafts and get a measurement to the center of the male end (mid travel) to the end of the smooth part where the yoke starts. Cut tubing and the use the tubing cutter town cut half the female spline end off. Take the cut end and lightly glue the extension piece, then insert being careful not to get glue in the splines. Then glue in the other end and your set. I crimp mine together with my tubing cutter instead of glue, works good. I'd suggest fitting the shaft for fitment before final glue assembly though. If any user would like to do a thorough write up on extended links and driveshafts, I'll sticky it for all to access easily. Just a thought guys. Last edited by Midlife Crisis; 03-03-2012 at 09:01 PM. |
03-03-2012, 01:22 PM | #3 |
Pebble Pounder Join Date: Jun 2011 Location: AREA 51
| Re: How to extend driveshafts |
03-03-2012, 02:20 PM | #4 |
Rock Crawler Join Date: Oct 2011 Location: Lexington
I simply bought an extra set of stock driveshafts, lopped off the ears of the male end and glued it to the female end. I don't think that would be long enough for the 5.5, but using Trail Trekker driveshafts would solve that. Took me about 20 minutes with some 5-minute epoxy, a hobby knife, and some sandpaper. They're plenty strong and lighter than aluminum tubing (albeit not quite as cool looking). There is also less room for screwing up since there's only one glue joint. |
03-03-2012, 09:07 PM | #5 |
Beaters...... Is that shrink tube extending that shaft? I can't quite tell exactly how you did that, but it looks good. Those wouldn't touch the wheelbase of the 5.5, the extension on mine ended up being 2-1/4" to 2-1/2" long......minus the yokes, etc. That chassis is long in the rear. |
03-04-2012, 02:10 AM | #6 |
Newbie Join Date: Jan 2012 Location: jackson
Man- ML Crisis/Beaters u both nailed it!! This is why so many of us love this forum- Thank you All, really-
03-04-2012, 06:43 AM | #7 | |
| Re: How to extend driveshafts Quote:
03-04-2012, 08:23 PM | #8 |
Quarry Creeper Join Date: Sep 2005 Location: Canon City
Here is a extended shaft using the tubing method..... |
03-08-2012, 02:45 PM | #9 |
Pebble Pounder Join Date: Jan 2010 Location: Roswell
The best way is to get a tube (I used a peice of antenna) that fits on the male driveshaft and glue it on. Then drill out the female shaft so the tube slides in easy but not too loose. Next drill a hole through the female shaft halfway down and and glue a pin in it, I used a small nail. Last put a slot in the tube so it slides past the pin. I just did this so I don't have pics yet. The easy way is to buy another driveshaft and cut just the shafts off and slide the male about halfway into the female and carefully glue it. You now have an extension that can slide onto the existing driveshaft. |
11-03-2012, 10:37 AM | #10 |
Newbie Join Date: Oct 2012 Location: W-S
I did mine out of 1/2" aluminium tube on WB8's |
11-03-2012, 12:38 PM | #11 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
i used 9/32 aluminum. i cut the tubular part of the drive shaft in half and glued the 2 pieces in the ends of the tube
11-03-2012, 02:22 PM | #12 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
I lengthened the rear shaft in a different way. I will add info here as well. Cut the Trekker shaft as shown. Drill into the ends slightly using a 5/32 drill. I did it by hand to have more control. About 1/8" is good. The drill only cuts the "threads" from inside the shaft. Cut a section of 5/32 styrene tubing and superglue it on both ends. Super easy and it looks better. |
How to extend driveshafts - Similar Threads | ||||
how to extend the 3 link | aljeann | Axial AX-10 Scorpion | 8 | 07-13-2008 01:53 PM |
How to extend links? | -Brian | Tamiya TLT Crawlers | 11 | 02-09-2007 09:54 AM |
How to extend axles | Washout | General Crawlers | 13 | 11-16-2005 07:16 PM |
how do I extend wheelbase? | Flatty | Tamiya Clod Buster | 5 | 09-02-2005 07:52 PM |
