05-17-2012, 02:04 PM | #1 |
Newbie Join Date: Apr 2012 Location: Seattle
| Lower Control Arm Axle Mounting
I know I've seen a thread where somebody moved the mounting location of the lower control arms on the axle. Hell if I can find it now... I'm thinking of taking the stock mounts and narrowing them by cutting 1/8th inch material off either end. Then threading the balls back on so they seat deeper into the existing mount. Anyone try this? I'm basically fine tuning my build now and would like to get a bit more clearance between the lower control arms and the HR Shock mounts. |
05-18-2012, 05:21 AM | #2 |
Pebble Pounder Join Date: Apr 2012 Location: Herndon
Sounds like a good idea. I noticed that with the HR Aluminum Gearbox, the left rear lower link binds up on the gearbox and limits that left rear wheel from rising all the way. The shock only compresses half way. Sent from my BlackBerry 9900 |
05-20-2012, 09:46 AM | #3 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
| Re: Lower Control Arm Axle Mounting
Black Rock...... what you are asking to do seems totally doable. There's plenty of real estate to do that andget the desired effect. The only problem I see with it is that you'll lose triangulation and possibly gain undesirable lateral axle sway. I say go for it, thetoyz.com sells axle housings if all else fails and it doesn't work out. |
Lower Control Arm Axle Mounting - Similar Threads | ||||
custom control arm measuring device | Elastokinematic | Losi Micro-Rock Crawler | 0 | 07-08-2011 08:48 AM |
Control Arm Woes / rant | JasonJones | Team Losi Comp Crawler | 11 | 07-25-2009 05:49 PM |
Axial control arm question | ariel | Newbie General | 4 | 12-05-2008 07:22 PM |
control arm limiter tabs.... | DJEEPER | General Crawlers | 3 | 12-31-2006 11:54 AM |
Broken Control Arm | DiabloXL | General Crawlers | 5 | 08-21-2006 12:23 PM |
