06-01-2012, 11:19 AM | #1 |
Newbie Join Date: May 2012 Location: Norway
| power consumption of the MRX-3100?
I want to change my MRX-3100 (RX/ESC in the Losi Micro Crawler) with something else, I want more channels. How many mAh does a new ECS need to manage? Anyone measured the power consumption of the little bugger?
06-01-2012, 03:14 PM | #2 |
| Re: power consumption of the MRX-3100?
After reading my own post I see that I haven't managed to write what I need to know. How many mAh does the motor pull? what should the ESC be rated at?
06-01-2012, 06:06 PM | #3 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
I don't know exactly how many amps the stock motor pulls ( Danally or getbent might know ) but most aftermarket micro ESCs that start at 18amps are plenty for the little crawlers and Im sure you would be fine with even less than that. most ESCs made for a micro or mini RC that use a motor the same size or larger than the losi micros should be fine as long as they have a reverse. |
power consumption of the MRX-3100? - Similar Threads | ||||
Power consumption and ESC/Motor questions | Mocca Master | Electronics | 2 | 10-24-2010 01:18 PM |
Anyone not using the stock Micro crawlers esc/rec? mrx-3100? i need 1 | yellowpasta2000 | Losi Micro-Rock Crawler | 2 | 05-21-2010 12:45 AM |
