01-25-2013, 08:36 AM | #1 |
Rock Stacker Join Date: Dec 2012 Location: canada
| transmition dig and 2 speed building!!!!!!!!!!
some body ask to me to built a micro dig transmition, i made it for losi axel but i have just a sumo transmition in stock for the built but i recomand to use with losi axel becose is a worm gear!!!! begin with any plastic sheet after you need a joint from any small rc !!! I use them from custum ridz drift car!!! for the bushing I use aluminium tubing!! shape the plate as you want and bolt em to the ball link!!! make a pin for the center shaft!!! and the finish product I ever run this type of dig on my micro and is realy a must!!!!!!!!! and a video micro dig unit for losi - YouTube next time will be the 2 speed |
01-25-2013, 09:19 AM | #2 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
| Re: transmition dig and 2 speed building!!!!!!!!!!
Nice work bud, looking forward to that 2 speed setup |
01-25-2013, 09:22 AM | #3 |
Pebble Pounder Join Date: Feb 2011 Location: Bulgaria
Wow,that was easy i thought it would be something super difficult.Great job on the dig and looking forward to see a 2 speed tranny |
01-25-2013, 09:24 AM | #4 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
Nice & simple Thanks for sharing. |
01-25-2013, 10:44 AM | #5 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
I like it! Motor must rotate when engaging rear drive train. Not sure of a way around it. :( Good job! |
01-25-2013, 11:01 AM | #6 |
it's why I use a soft material if is not in front of the pin the plastic bend and when the shaft turn it will engage easily!!! you also can drive it by spring!!!
02-09-2013, 06:47 PM | #7 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
whens part 2?
02-12-2013, 07:53 PM | #8 |
Rock Crawler Join Date: Oct 2011 Location: minot
soooooooooooo doing this!
02-12-2013, 09:51 PM | #9 |
if nobody see the micro FOFF to i post 2 week ago is 2 speed transmition!!!! a couple of good pic of building,!!!! in one week I coming back to my home and start a new 2 speed !!!! but now you have to find a 2 speed cheap truck and material for the casing me i use teflon becose I don't bearing! and keep the motor gear is the most important!!!!!!!!!!!!!!!! take a look FOFF Iceland style |
03-20-2013, 12:10 AM | #10 |
IT'S TIME !!! to built !!! you need a dremel ,a drill ,some teflon(I use this becos is easily buidable and very low friction and usure!!!, 2 speed gearing!!! and a lot of time!!! if you are luky you will have the good shaft diameter!!!if not like me now you will have to turning down with a dremel and drill on shaft!!!in my other transmition I gluted the output shaft on the gear but this one is bigger and have spline starting kit these gear come from a 1/12 vintage camaro and was a couple run on 3 cell with no damage now i make a hole in the skid plate for place the shaft lower, it's not necesary, I make it for less draving angle!!!! mark a point for the output shaft now the output shaft is in place, TRY to place the idler gear shaft in the good spot with a good gear mesh!!! mark with a small point mabee you will not do the first time!!! note : iT's easier to losen the gear mesh than make it tigthen!!! now everything is ok just take this gabarit for the other side!!!! now let in the hole and drill the other this is not the motor I will use!!! just drill big hole for the gear and motor , and2 small for the bolt,,,,,,,,,,, and ,,,,,,,,now a lot of work rest to do but I don't finish im becose I don't know where he gone a go!!!! thi is not easy to built but is very a must!!! and it is pretty strong, I never broke this type of transmition in a losi will give you a super low range and a segond gear a little bit faster than the stock one!!!! IN A SUMO CRAWLER IT'S INCREDIBLE!!!! with the losi esc the red cat smoke too much!!! I wish thats will help somebody to built a transmition |
03-20-2013, 08:50 AM | #11 |
ha i forgot this pics, every thing is in place,take a look of this spiderman rim with sumo tire they look awsome!!!! |
03-20-2013, 09:10 PM | #12 |
how do you switch gears?
transmition dig and 2 speed building!!!!!!!!!! - Similar Threads | ||||
Speed building on the cheap. | Mr.JayDeeM | Formula Offroad | 23 | 09-04-2012 08:54 PM |
Speed building on the cheap. | Mr.JayDeeM | Axial AX-10 Scorpion | 10 | 08-21-2012 11:38 AM |
which transmition? | crawling71 | Axial AX-10 Scorpion | 6 | 10-09-2011 04:15 PM |
creeper transmition | ryan772 | Venom Creeper | 9 | 04-14-2010 05:23 AM |
transmition problem | smedo | Axial AX-10 Scorpion | 7 | 06-26-2009 03:18 PM |
