10-13-2013, 09:22 PM | #1 |
Newbie Join Date: Sep 2010 Location: central
| Josh's μCrawler
Thought I'd share my my Micro with you guys. Thank you guys for all your intuitive posts. I moved the shocks inward and changed their pivoting direction. Don't know were that hair came from I just cleaned my axles! Glued carbon rod upper links 1 piece threaded(had to buy a die and rod to thread these) carbon covered bottoms(all purchased at HobbyTown). Losi Lipo battery just clears gear looks sketch but no problems yet. Stock drive shaft The rubberband that holds on my battery also work as shock limiters to give the rear a slight lift. Patriot servo from HobbyTown. Stock wheels and tires. I have a weighted set but this truck is running too good right now. Thanks, Josh Last edited by Mike Rawler; 10-13-2013 at 10:02 PM. |
10-13-2013, 09:28 PM | #2 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: Josh's μCrawler
Looks good man! just resize that last pic.. it is way too big!!!!!!!! looks cool... some simple little mods and yeah these things do great...... |
10-13-2013, 09:50 PM | #3 |
Quarry Creeper Join Date: May 2013 Location: Chino
| Re: Josh's μCrawler
Where did you get the bug body?
10-13-2013, 09:55 PM | #4 |
| Re: Josh's μCrawler
How I fixed my transmission part of a Bic lighter and part of a very small thin spring. No more dragging and burning up motors. |
10-13-2013, 10:10 PM | #5 |
| Re: Josh's μCrawler
i vacuum formed it from a Beetle purchased at Cracker Barrel. Bought the lexan sheets from HT usa, pegboard, and shop vac. I attached the lexan to a frame and heated it in the oven. If I remember right I did it with the door open keeping an eye on how saggy it got. Set the car on top of the sealed box except the side that is pegboard and attached to the vacuum. You then push the frame tightly over the car. Clear as mud? |
10-13-2013, 10:40 PM | #6 |
| Re: Josh's μCrawler
Ya know given thought to this you probably could get away with a heat gun. I may give this a try.
10-13-2013, 11:52 PM | #7 |
| Re: Josh's μCrawler
note: Heatgun didn't work. At least on this really tall square Defender 90 body I just tried. I have another sheet maybe I will try to vacuum one of it tomorrow. |
Josh's μCrawler - Similar Threads | ||||
Josh's 2013 sporty build | Joshie | Axial AX-10 Scorpion | 23 | 07-07-2013 04:23 AM |
Josh's TOUGH truck 1.9 hilux | rocksteadily | 1.9 Scale Rigs | 91 | 04-16-2013 09:40 PM |
Josh's tj ttc | upoveryou | 2.2 Scale Rigs | 3 | 03-16-2011 02:35 PM |
josh's scx-10 (first scaler) | josh97 | Axial SCX-10 | 6 | 04-22-2009 09:19 AM |
