12-02-2013, 10:07 AM | #1 |
Newbie Join Date: Dec 2013 Location: Cincy
| What lipo charger is suggested?
I got some battery ideas from the forum . The venom 250 was suggested.How about a charger recommendation. Thanks Tim
12-02-2013, 01:21 PM | #2 |
Quarry Creeper Join Date: Feb 2013 Location: Detroit
Pretty much how much charger u want. You can make anything charge safe & good if its digital has a balancer & adjustable. Things that upgrade a charger Electric fans Large range of lipo cells capable of charging Ac/dc/Voltage-some take a power supply for dif kinds of batterys other than lipos Multi chargers are now easily available For a baseline single battery charger thats digital & has a balancer & will plug into the wall i wouldnt break $100. |
12-02-2013, 02:42 PM | #3 |
Quarry Creeper Join Date: Jan 2013 Location: LP, LA
| Re: What lipo charger is suggested?
Been using an Ascend by Radient. Compact size, AC/DC operation, cooling fan, digital controls, charges 2s and 3s, has balance plug and costs about $30.
12-02-2013, 04:47 PM | #4 |
Rock Stacker Join Date: Jul 2012 Location: MS
I have a turnigy accucell 6 and an imax b6 which is basically the same chargers and both under $30. you will need a power supply for both and they can charge discharge and balance up to a 6s battery and has settings that go down into tenths so they are perfect for charging our below 1000mah batteries
12-02-2013, 08:25 PM | #5 |
Rock Stacker Join Date: Dec 2012 Location: SF Bay Area
I have a GT Power Xcharger C6 which is basically a accucell 6. Has built in balancing ports, does lipo, life, nimh, nicad you name it. Pretty good value at about $35 with the power supply. Just another model to consider.
12-03-2013, 05:07 AM | #6 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
so interesting people referencing the balance feature.. I havent gotten up the cahones but I know Danally cuts off his balance plugs to make less wiring for these lil guys and hasnt had a problem yet.. I still prefer my balance plugs... I have the thunder ac6 and it does well.. Thunder AC6 Smart LiPo Balance Charger/Discharger w/ AC Adapter for 1-6 Lipo/ 1-15 Nimh + USB to PC Software |
12-03-2013, 04:43 PM | #7 |
Had couple of Losi lipos without balance plugs for a while. Used the Losi charger and they did fine. My current charger won't charge one without a balance plug though.
12-03-2013, 05:30 PM | #8 |
^the losi lipos have built in overcharge/overdischarge circuitry. This probably limit the charge current from your charger.
12-03-2013, 06:28 PM | #9 |
Sounds like the $30-$40 Chargers are all about the same. That or they are copies. I ordered up the Accuell 6. Thanks for the opinions. This little Trekker is fun on the 4.8v I cant wait till the lipo
12-04-2013, 01:54 AM | #10 |
| Re: What lipo charger is suggested? I just read about your charger and you are right, it wont charge any lipo without a balance plug. It appears it is a safety feature by design.
What lipo charger is suggested? - Similar Threads | ||||
Replacing fan in lipo charger - Venom Pro Charger | iamsuperbleeder | Electronics | 11 | 04-04-2012 08:06 PM |
suggested battery and charger? | always eating mud | HPI Wheely King | 7 | 07-21-2007 06:12 PM |
