12-10-2013, 09:21 AM | #1 |
Pebble Pounder Join Date: Jul 2013 Location: Williston
| Newbish Trail Trekker questions
So I just pulled the trigger on a trail trekker last night and decided to throw a lipo in as well. The lipo pack I have is a 430 Mah 20c 7.4. Everything seems to run perfectly fine for the most part. I have two concerns though. on the first pack I noticed that full throttle straight driving I would rarely see a twitch in the steering servo. You could actually see the truck swerve for a second. I also noticed the motor is getting pretty darn hot after around 10 minutes. Is the stock motor just going to burn out after 3 packs and people are just failing to mention they have replaced them when they talk about running lipos or is it just going to normally run that hot? Should I be worried about the servo at this point as well? Also I couldn't find any info on the stock esc anywhere, the red light that shines when you plug in a lipo versus a NiHM. Is that just to show that it recognizes the battery as a lipo? Cheers, Dick |
12-10-2013, 12:29 PM | #2 | ||
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: Newbish Trail Trekker questions Quote:
with that.. even though you are only running a lipo and no other mods.. that lipo is pretty big (I run 180 and 350mah 2s lipo) so maybe the extra weight and if the slipper clutch isnt slipping (as we glue ours ) the motor will heat up and eventually go. Quote:
to me there are a few first mods to any trekker.. even if keeping in a truck form to play with.. 1. lipo - just why not full power till lipo cutoff.. and I have yet to play and kill 1 x 350mah 2s lipo so having 5.. i would be bored by then!!!!!!! 2. motor - without a doubt even a rewound 90t stock can from Danally is a necessary item | ||
12-10-2013, 01:09 PM | #3 |
Thanks for the input. I actually did pull the weight on both batteries. The Stock NiHM clocks in at like 24 grams, while the lipo I have is 34. I haven't taken a temp on the stock motor after running but its hot enough for me to not want to touch it for sure. Esc stays cool. I don't mind investing in another motor so sounds like that will be my first move. Guess I will just have to see how many runs I can get outa the stock before it burns up. |
12-10-2013, 07:53 PM | #4 |
Pebble Pounder Join Date: Jan 2013 Location: south jersey
This is good to know,I get to look at mine on the shelf till Xmas,but do have the losi lipo and charger waiting
12-11-2013, 05:01 AM | #5 |
90T from Danally ordered. Running last night I didn't see any of those servo jumps I noticed the first pack. Maybe it was a fluke. Now I just have to deal with the massive amount of hair that my drive line picks up from my wife's constant shedding. |
12-11-2013, 06:19 AM | #6 | |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
12-11-2013, 07:12 AM | #7 |
Quarry Creeper Join Date: Feb 2013 Location: Detroit
A Y-harness plug into same spot for steering on esc. Then plug steering back in & add an electric fan to the motor side of the frame rails. Its will stay cool. I used to do that cuz had that stuff lying around. But now have a 90t w glued slipper. The servo is junk. Even the cheap metal gear servo's twitch. Mine does at full reverse. You should ditch the servo saver when u upgrade the servo, & just add the horn that comes w a new 1. |
12-12-2013, 06:14 PM | #8 |
Newbie Join Date: Jun 2013 Location: Virginia Beach
Careful w your lipos. Theres no cut-off on the micro crawler esc! The losi/excelorin lipo/charger is good for that reason. Auto cut-off(running and charging) is built into the battery. But theyre pretty outrageously priced.I think around 50-60$. Ive been running 250mah 20c 2s venoms-$10 each. .stock esc still good after at least 30 runs.
12-12-2013, 06:32 PM | #9 |
Quarry Creeper Join Date: Jan 2013 Location: LP, LA
The factory micro rcvr/esc does have lipo cutoff. It seems to be set kinda hi in fact. My Venoms hit cutoff around 6.8v or higher. Edit: Read the Jan. 2012 thread by Rockfrog: "Straight from the horses mouth" Last edited by anuthabubba; 12-12-2013 at 07:13 PM. |
12-21-2013, 07:13 AM | #10 |
Finally got around to putting in the 90t I got from Danally last week. SO MUCH better than the stock can. Loving it. Longer run times, not more heat issues, and performs great. I also picked up a Hitec HS-65MG servo to replace the stock one. Again, a very welcome upgrade. No more steering glitches and has tons of power. Next up is wheels/tires.... Cheers, Dick |
12-21-2013, 09:14 AM | #11 |
RCC Addict Join Date: Jun 2007 Location: MESA
Glad to hear it! I make bead lock rims too |
Newbish Trail Trekker questions - Similar Threads | ||||
Trekker link questions | agent00111 | Losi Micro-Rock Crawler | 17 | 06-01-2012 11:11 AM |
trail trekker | MaD222 | Losi Micro-Rock Crawler | 1 | 05-05-2012 08:05 PM |
1/24 Trail Trekker | Dr.Newb | Micro Scale Rigs | 2 | 04-27-2012 09:10 PM |
thinking of getting a LMC or trail trekker, couple quick questions | noremacyug | Micro Scale Rigs | 13 | 04-27-2011 12:20 PM |
starting a project(newbish) | Nylintbucket | Tamiya TLT Crawlers | 7 | 09-01-2009 10:43 AM |
