06-13-2014, 05:12 PM | #1 |
Newbie Join Date: Feb 2014 Location: Nor Cal
| 4w steering help
Hay guys, modding my trekker for 4w steer using stock losi servos. when plugging them into a DYI Y-connector matching wires color for color, it does a crab walk. Question is whats the wire color combo for the rear servo to make it right?
06-13-2014, 07:51 PM | #2 |
Pebble Pounder Join Date: Jan 2010 Location: Anchorage
| Re: 4w steering help
You'll need a servo reversing harness
06-13-2014, 11:53 PM | #3 |
| Re: 4w steering help ok, thanks GVUS.....I did a search & couldn't find the harness but I did find a good you tube vid about revering the servo itself How to Manually Reverse a Servo - YouTube I did it & it worked used the Losi stock servo. Figured no harm if I fryed it. |
06-14-2014, 06:00 AM | #4 |
Rock Stacker Join Date: Jul 2013 Location: Northern 801
Great info, does the servo still need reversing if its not fulltime 4ws, but operated by a 3 pos toggle on the tx? Probably Sent Sitting On The Toilet... |
06-15-2014, 10:51 PM | #5 |
| Re: 4w steering help [QUOTE=HPI-Killer;4805510]Great info, does the servo still need reversing if its not fulltime 4ws, but operated by a 3 pos toggle on the tx? Not sure its possible to hook it up to the 3rd channel since theirs only 1 steering input on the stock receiver. But I did find this on another thread Bastens QuadSteer 4 wheel steering control module works with either 2Ch or 3Ch transmitters it was posted by PatsPosts on this thread 4 wheel steer help |
12-28-2014, 07:55 AM | #6 |
Newbie Join Date: Dec 2014 Location: small town
PriMEd thanks for the youtube video Did you ever try to swap the 3 wires in the plug?
4w steering help - Similar Threads | ||||
Idea for scaler steering... Need ideas for building a steering box. | JavelinSST390 | General Scale Talk | 25 | 05-14-2015 02:32 PM |
new steering on the new PRO/ OTA steering mod axialjeepster | AxialJeepster | Losi Mini-Rock Crawler | 4 | 10-14-2012 01:03 AM |
inside tyre touches steering knuckle / steering linkage | murky123 | Axial SCX-10 | 4 | 10-06-2010 04:46 PM |
Hot Racing Steering knuckles - more steering than the original plastic ones? | Tomy | Axial AX-10 Scorpion | 1 | 11-16-2008 11:26 AM |
