12-19-2018, 05:27 AM | #21 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Re: AnimalHippie Goes Micro!
Spent some time in the garage last night. Pulled the shocks off the black trekker and the RX out of the dingo and plugged everything in on the comp rig. so I could find out what is what. It moves! It wasn't moving like it should tho. Very jerky and weird. Figured ESC probably needs calibration. When I went to do that I found one of the motor wires had come lose. The motor is a cool tiny revolver type motor. Didn't know that till I put power to it. I will try to rewire it next time I get some time. Almost looks like it's one wire that comes out of the motor then splits into 3 going to the ESC. The motor is a Spin HO46-8800kvAnyone have any experience with this motor? Also have to pull the servo off the trekker and put it on this rig. Which is fine with me it's a better one anyway. The one that's on it doesn't work at all. Here's a few pics Last edited by AnimalHippie; 12-19-2018 at 05:49 AM. |
12-19-2018, 05:34 AM | #22 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
I haven't messed with brushless motors in some time but pretty sure that's why it was jerky, calibration may have a little to do with it but pretty sure if you connect that wire back up it'll be much smoother.
12-19-2018, 08:51 AM | #23 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: AnimalHippie Goes Micro! Quote:
Just a few tidbits for ya! Ernie | |
12-19-2018, 09:38 AM | #24 | |
12-21-2018, 11:23 AM | #25 |
Well this little guy is still fighting me. Pulled the electronics out of it. Found another wire that the solder joint came loose. Resoldered it and got the motor to work. Put it back in the rig powered everything up and 2nd pull of the trigger the plastic pinion gear came off the motor shaft . Kinda aggravating, but that's life. Did some research on this little motor and after translating the web page. I found that it's a helicopter/drone motor and doesn't like much of a load. Hoping I can make it work out, but idk. Might have to look into other brushless micro motors or go brushed. I think I'm gonna put these little guys on the back burner for a few till I can gather up a few things for them. I don't like stuff to sit so I'm sure it won't be long till these guys are back on the bench.
02-23-2019, 06:25 AM | #26 |
Ok started looking back into working on these little guys. For the micro T I'm looking at this ESC https://www.gearbest.com/multi-rotor...pp_180563.html and using my tactic 200 RX/TX. Also a set of losi micro crawler shocks. Around $25 should get it going. The micro crawler I'm not sure my plan yet. Have found a place in Europe somewhere that makes any gear you could want for my pinion gear. Only issue I have is I'm not sure if it will even fit. Guess I could do some custom work to the motor plate. The spur gear is a HR 56T. I'm thinking a 15t pinion should be about the right tooth count? The motor that's in it is a spin HO46-8800Kv with a 1.5mm shaft. Other option is to get a different bl motor, but don't know if that would make any difference. Here is the ESC that's in it Also need a servo for it. Probably go with the hitec 5065 just like the micro T has unless there's a better choice/price for that application. Let me know what you guys think. Thanks for any help |
03-05-2019, 12:11 AM | #27 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
I'd get a 9t or 10t pinion. 14t is way to big IMO Sent from my LGMP450 using Tapatalk |
03-05-2019, 05:54 AM | #28 | |
03-05-2019, 07:14 AM | #29 |
If it doesn't reach try slotting the motor plate holes Sent from my LGMP450 using Tapatalk |
03-05-2019, 07:17 AM | #30 |
Being a outrunner the motor can't touch. Notched the motor slots and found out that motor touched the trany case before gear was close enough.
03-15-2019, 02:42 PM | #31 | |
Hey Justin, I found a box with a few more Micro parts with some shocks for you. I will put together a care package later and send it your way. Ernie | |
03-15-2019, 02:51 PM | #32 | |
You're amazing brother! Thank you!!! I've been getting an order together to get these guys going. Just waiting on uncle Sam to send me a check. | |
03-21-2019, 11:46 AM | #33 | |
Were those the shock parts you have been needing? Not sure if those are all micro parts for your trucks. The kids across the street use to have a couple losi micro 2wd trucks that I bought parts for. I haven't seen them out running them for quite awhile so I think they finally trashed them. Have fun, Ernie | |
03-21-2019, 11:55 AM | #34 | |
I believe so. Still going to need to buy a set of shocks tho. Only 3 in that package are usable. That will give me some spares :-) always good to have back ups. Now just waiting on uncle Sam so I can get the other things for these guys. Appreciate the care package brother! Always having fun :-) | |
04-02-2019, 04:57 AM | #35 |
Quarry Creeper Join Date: Jan 2014 Location: round lake
Can't wait for your parts to show up!
04-12-2019, 08:52 AM | #36 |
Alright, finally got my parts I ordered from China! I went ahead and pulled the brushed motor and trans out of the trekker and installed it in the comp crawler. Installed the micro brushed ESC I picked up from AliExpress. Decased a tactic 3ch rx. Also put the hitec servo from the trekker on it as well. IT MOVES!!!! I'm so extremely stoked! Now just have to figure out where to put the battery, ESC & Rx where the wires and everything will be out of harms way. Probably going to make a electronics tray out of some thin plastic or aluminum sheet. I will post some pics once I get everything sorted out. Going to try to get it on the rocks this evening at some point. Shot a unboxing/install video that I have to do some editing on before I can post it. I'll post that link as well once it's done. |
04-12-2019, 09:23 AM | #37 | |
04-15-2019, 11:17 AM | #38 |
Here it is! Still needs a little work, but it runs great! Everything packed in nice and tight. No room for anything else. Made a electronics tray from some plastic from the oil jugs I used to make inner fenders on my Trx-4. Worked out great! Driveshaft in the rear rubs the motor in one spot and need to shorten the center pieces of the driveshafts a little too get full flex on both sides. I'll get that done soon. Really like running this little guy. So glad that it's up and running. Now time to get a list for the trekker. Gonna get some crawl video of it sometime this week. Thank you again Ernie!!! The girls are loving running this little guy. They also send their love and hugs! Joss says she likes it better then the 1:10 rigs cause " it's so cute!" Lmao! Last edited by AnimalHippie; 04-15-2019 at 11:50 AM. |
04-15-2019, 01:31 PM | #39 |
Looks awesome! Sent from my LGMP450 using Tapatalk |
04-15-2019, 04:59 PM | #40 |
Good to see you got one of them up and running!!! Tell Joss We would like to see some pics of her and her sister! Marcia and Ernie |
AnimalHippie Goes Micro! - Similar Threads | ||||
Castle Creations Micro Mamaba X problemI have the micro mamba x with a 4100kv motor, | Steelone232 | Electronics | 1 | 06-12-2018 08:56 PM |
Micro Terrain Titans + Matchbox Baja Bug = Micro Monster Beetle | nascarkeith | Non Crawler RC's | 14 | 04-06-2009 01:25 PM |
