09-23-2008, 11:59 AM | #1 |
Rock Crawler Join Date: Jun 2007 Location: Hopewell
| Recommended Replacement Servo?
So my stock servo meet its final death yesterday. It started the little whine/click noise on it's first real rock outing but could still turn. I was running it like that yesterday and now it's pretty much toast. It just whined and wouldn't turn until the wheels were completely free. So, now the question is what is the best replacement servo? I've seen throughout different threads where guys are running Hitec 225's but they seem to weak imo. Saw some Hitec HS 82's, not sure how durable they are. And some have even used full size Hitec 645 servos. But I'm interested to see what else are people running, reliably. I was hoping to have one thread where people can find this information instead of searching through all of them. So what replacement servo's are you guys that have switched running? And how is the performance, durabilty? Is full size too much? |
09-23-2008, 12:25 PM | #2 |
Pebble Pounder Join Date: Aug 2008 Location: orlando
well i've gone through one stop and two hitech 255's all burned up from over use, not meant to have the wheel cracked to one side or the other very long i run a total of 4oz up front in the tires they all got hot and just died switch to the hitech 645. had to build a new mount i saw nothing on the boxes (255 or 645) that sait the voltage output would hurt. same draw as far as the 645 goes... i drove it hard the other day went through 2 (stock battery and a 1600 7.2 nimh) batteries from full to empty and had no issues... the esc didn't get hot like it would with the stock servo or the 255's and the 645 did not get warm i do plan on upgrading the ecs and adding a bec, but for now it works so far i've done the upgrade to two MRC's this is just what i've done... kinda new to the crawler scene and if anyone has something else that works better i'm all for it Last edited by uberalles; 09-23-2008 at 12:26 PM. Reason: missing something |
09-23-2008, 12:29 PM | #3 |
oh 60 oz at 6v on the 255 133oz at 6v on the 645 |
09-23-2008, 08:25 PM | #4 |
Newbie Join Date: Aug 2006 Location: Santa Cruz
I bought a four Hitec 225 mg's a while ago on a servocity blowout. Like 10 bucks each. I used to run them in my Nylints and I thought they held up really well. First thing I did was stick one in the MRC and keep the stock for a backup. Seems much better than stock and is a perfect fit. I've thrashed it pretty hard and it's working. Should be no problem to put whatever servo you want on one of these but these with slight mods, mini servos like the 225 just bolt right in. They have 67 in/oz of torque. Wonder what the stock one has?
09-23-2008, 08:33 PM | #5 |
varcor.org Join Date: Aug 2005 Location: 757
according to the horizon hobby catalog, the stock MRC servo is: torque: 4.1 kg/cm @ 6v ( 57 oz/in @ 6v ) speed: .16 sec/60* @ 6v weight: 28 g size: 34 mm x 16 mm x 35 mm (1.3 in x .6 in x 1.4 in) dual ball bearings |
09-23-2008, 09:07 PM | #6 |
RCC Addict Join Date: Jun 2008 Location: Fresno
not sure if this is concidered thread jacking but, ive been hearing about people burning up their stock and 225 servos, for those of you who have, are you sure your epa's are set correctly? i ask because, ive been using the stock servo since the mrc was released and ive yet to burn it up. |
09-23-2008, 10:02 PM | #7 | |
09-23-2008, 11:00 PM | #8 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
I'm using the HS-82MG in my modded MRC and it continues to work fine. I will say that running a Micro servo is not for everyone, you must be very secure in your masculinity as people might point and laugh at your tiny servo doing all the work. Last edited by badger; 09-23-2008 at 11:05 PM. | |
09-23-2008, 11:37 PM | #9 | |
RCC Addict Join Date: May 2005 Location: Auburn, WA
09-24-2008, 05:39 AM | #10 |
you can adjust your end points on the stock radio, the adjustment is just to the the right of the on/off switch. the stock radio stripped out on me, i run a solid arm no servo saver as far as the adjustment goes on the end point i run it between min and the middle on the dial if that makes sense. 133oz at 6v on the hitech645....that's hard to beat plus the few oz of added weight on the front i have had zero issues with the big servo |
09-24-2008, 04:03 PM | #11 | |
09-24-2008, 06:44 PM | #12 |
Let me 3D Print that... Join Date: Jun 2007 Location: Concord
I picked up one of these tonight and was pleased to find a stripped servo as soon as I sat it on the ground to run it for the first time...on carpet. That is kind of poor that it comes right out of the box like that... Guess I will be upgrading like everyone else. I was sort of looking forward to using the stock parts in this thing for a while and not spending any money on it. :-( |
09-24-2008, 09:00 PM | #13 | |
PM me your addy and I will ship you my brand new servo I pulled off my modded rig tomorrow. | |
09-24-2008, 09:27 PM | #14 |
Badger, Thanks for the offer man, but I don't want you to go through the trouble just for me. To answer you question, no, the servo saver was not on. I swapped out for the solid arm right away. When I set it down and was doing a radio check I noticed a clicking in the travel, before it even reached the end of travel. I was curious, so I took the servo apart tonight. Sure enough one tooth was missing on the gear that sits almost directly over the motor inside. Unless this is just a fluke, I feel like a metal gear servo may be the only way to travel with this thing. I put the servo back together and it works...just has a clicking sound that gets worse under load. Who knows how long it will last, but hopefully long enough to make a trip to my LHS for a better servo. |
09-24-2008, 09:55 PM | #15 | |
If you can flip the gear around 180* and it shouldn't hit that missing tooth through the turning range. And put the servo saver back on. | |
09-24-2008, 10:28 PM | #16 | |
So far it looks like a few guys have burned up 225's and a few have used them with no issues. And Badgers Hitec HS82 has been working, but that micro seems too small for me. Has anyone burned up or stripped out the gears in a 225 after setting the EPAs correctly? And are there any other servos that can be used, I really don't want to use a full size servo. I did some comparisons and I've narrowed it down to two servos. I already have a HS225 and quite a few others are trying it, so I don't want to test that one. I'm going to either go with a Hitec HS5245MG or a HS5085MG. Both have more torque than a stock servo. I'm leaning towards ordering the HS5245MG for pretty obvious reasons, more torque and no bushings or nylon. Here are the specs on both (and the 225MG) HS5245MG Operating Voltage: 4.8-6.0 Volts Operating Temperature Range: -20 to +60 Degree C Operating Speed (4.8V): 0.15sec/60° at no load Operating Speed (6.0V): 0.12sec/60° at no load Stall Torque (4.8V): 61 oz/in. (4.4kg.cm) Stall Torque (6.0V): 76 oz/in. (5.5kg.cm) Operating Angle: 45 Deg. one side pulse traveling 450usec 360 Modifiable: Yes Direction: Clockwise/Pulse Traveling 1500 to 1900usec Current Drain (4.8V): 3mA/idle and 180mA no load operating Current Drain (6.0V): 3mA/idle and 230mA no load operating Dead Band Width: 1usec Motor Type: 3 Pole Ferrite Potentiometer Drive: Direct Drive Bearing Type: Dual Ball Bearing Gear Type: 4 Metal Gears, 1 Resin Gear Connector Wire Length: 11.81" (300mm) Dimensions: 1.3" x 0.7"x 1.2" (32 x 17 x 31mm) Weight: 1.12oz (32g) HS5085MG Operating Voltage Range: 4.8-6.0 Volts Operating Temperature Range: -20 to +60 Degree C (-68F to +140F) Operating Speed (4.8V): 0.17sec/60° at no load Operating Speed (6.0V): 0.13sec/60° at no load Stall Torque (4.8V): 50oz/in. (3.6kg.cm) Stall Torque (6.0V): 59.7oz/in. (4.3kg.cm) Operating Angle: 45 Deg. one side pulse traveling 400usec 360 Modifiable: Yes Direction: Clockwise/Pulse Traveling 1500 to 1900usec Idle Current Drain (4.8V): 3mA at stop Idle Current Drain (6.0V): 3mA at stop Current Drain (4.8V): 200mA/idle and 2.0 amps at lock/stall Current Drain (6.0V): 240mA/idle and 3.0 amps at lock/stall Dead Band Width: 2usec Motor Type: Carbon Brush Potentiometer Drive: 6 Slider Indirect Drive Bearing Type: Dual Ball Bearing MR106 Gear Type: Metal Gears Connector Wire Length: 7" (178mm) Dimensions: 1.14" x 0.51"x 1.18" (29 x 13 x 30mm) Weight: .77oz (21.9g) HS225MG Operating Voltage: 4.8-6.0 Volts Operating Temperature Range: -20 to +60 Degree C Operating Speed (4.8V): 0.14sec/60° at no load Operating Speed (6.0V): 0.11sec/60° at no load Stall Torque (4.8V): 54.15 oz/in. (3.9kg.cm) Stall Torque (6.0V): 66.65 oz/in. (4.8kg.cm) Operating Angle: 45 Deg. one side pulse traveling 400usec 360 Modifiable: Yes Direction: Clockwise/Pulse Traveling 1500 to 1900usec Current Drain (4.8V): 8mA/idle and 300mA no load operating Current Drain (6.0V): 8.8mA/idle and 340mA no load operating Dead Band Width: 8usec Motor Type: 3 Pole Ferrite Potentiometer Drive: Indirect Drive Bearing Type: 1 Ball Bearing and 1 Oilite Bushing Gear Type: 4 metal and 1 nylon Connector Wire Length: 11.81" (300mm) Dimensions: 1.27" x 0.66"x 1.22" (32.4 x 16.8 x 31mm) Weight: 0.99oz (27g) | |
09-25-2008, 06:16 AM | #17 |
i've killed two hitech 255's one may have been because the end points. but the second one was not .... just not meant to hold a position.... it got hot and then died 645 is about a 1/4" bigger and i have had zero problems ... plus 133oz is hard to beat in this little rig |
09-25-2008, 07:08 PM | #18 |
Rock Crawler Join Date: Mar 2008 Location: Arizona
I have a JR sz590 (metal gear servo that came with my Radio) I would recommend a full size servo probably a Hitec 645 would be way more than enough and work well, you just have to fab a plate up to fit the slightly larger servo. |
09-26-2008, 06:33 AM | #19 |
Newbie Join Date: Sep 2008 Location: dallas
| traxxas 2075
I went with the full size traxxas 2075 digital servo rated at 125 oz. This was the best upgrade besides the added wheel weights. I used a ax-10 front servo plate & drilled it out to match the mounting holes on the losi. The fit is perfect. This servo is a beast, it's performance is what I was looking for.
09-26-2008, 07:34 AM | #20 |
RCC Addict Join Date: Nov 2007 Location: E.T.R.C.
Will the bec in the speed control handle the full size servo ok ?? Anyone had any problems with this ??
