12-08-2008, 01:33 PM | #1 |
Pebble Pounder Join Date: Sep 2005 Location: So Cal
| HR Aluminum Spool
Does this aluminum diff. spool from HR replace the stock plastic differential locker? In other words can I use this instead of the metal locker from Losi? (Part # LOSB1433) Just want to make sure, anybody try these yet? Thanks. Losi Steel Locker (Part# LOSB1433) |
12-08-2008, 01:47 PM | #2 |
Rock Crawler Join Date: Mar 2008 Location: lodi
well the losi are steel i beleave so they will be much stronger then the alum hr ones the hr ones could be prone to warping like the stock axial ones but it could also take a while to do so it could work fine
12-08-2008, 05:59 PM | #3 |
RC Axle Master Join Date: Mar 2008 Location: Las Vegas
The losi steel work great and they hold the axles alot thighter then the plastic. I also was afraid that the aluminum would wear alot quicker then the steel lockers.
12-08-2008, 07:17 PM | #4 |
Rock Stacker Join Date: Oct 2008 Location: US Army / Iraq
I went with the HR's. It's difficult for me to get any Losi parts in Iraq, so I deal with Liquid RC. Anywho's, I just got mine last night and I will have them installed in a day or two. Aluminum may not be steel but it's got to be better than plastic! |
12-08-2008, 08:09 PM | #5 | |
Quarry Creeper Join Date: Nov 2006 Location: Longmont
My homebrew aluminum lockers are holding up fine. No sign of wear after a few weeks of hard use. See this thread: http://www.rccrawler.com/forum/showt...78#post1464678 | |
12-08-2008, 11:54 PM | #6 |
I'm currently installing the lockers now... I'm also installing a set of aluminum driveshafts. I gotta tell you, I'm impressed with the machine work of these aftermarket parts. I'm also impressed with the ring gear/housing of the steel Losi component and the pinion gear, BUT... I'm very dissapointed with the small (1mm?, .5mm?) hex screws. For the first time I'm all over this kit replacing hex's with cross tip screws. The little "grub screws" are kicking my butt. I'm also noticing some gear lash with the pinion/ring, meaning something isn't sitting just right, but I should be able to work that out with some pinion washers. All that said, these lockers look like they will really work out nicely. |
12-09-2008, 08:40 AM | #7 |
Well, about 4 hours later I got the lockers installed. Losi... Please don't use loctite on such tiny screws! You know we are going to replace plastic lockers! Luckily I have 2 MRC's so I had to scavenge a couple of parts. I had to actually cut off two u joint housings because I coudn't get the set screws out. But, I got it all complete and ran the truck thru a battery. I was quite pleased, all aluminum driveline. It was oddly smooth and actually, I felt like it was performing much better on my little test pile. I'd swear the throttle was more responsive. Perhaps I just wanted to believe it because I almost doubled the cost of my investment... |
12-09-2008, 08:51 AM | #8 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
How are you liking those alum drive shafts? Did they install easier than the lockers. I have a set of the lockers ordered. What was the hardest part of installing them? Any suggestions for install?
12-09-2008, 10:39 AM | #9 |
The drive shafts are cool, fully rebuildable but I'll probably never need to. They have a smaller diameter drive shaft, but a much beefier "u joint". may help reduce hang ups, may not. I'll need more time. The actual install is a breeze. It's the tiny screws that are a pain. My recommendations? *High quality tiny screw drivers *high quality hardened hex keys *mini torch for heating up the Loctite (You will melt the plastic too, I'm sure.) |
12-09-2008, 01:21 PM | #10 |
Thanks for the info. Sounds like a 2 beer minimum project.
12-09-2008, 02:16 PM | #11 |
| You might try holding a soldering iron to the head of the screw for a few seconds, rather than the torch. You'll probably still melt the plastic a bit, but there is a much better chance of it being reusable. I have had good luck releasing loctite on small fasteners with this method.
